FI Decision Thread
Old Mar 13, 2010 | 08:22 AM
  #61
WhosUrBuddiee's Avatar
WhosUrBuddiee
I know the trade off for supercharger and turbos but beleive that is only for people who really plan on pushing their car. Maybe I am different but I am not going to beat on it. It will mostly sit covered unless there is a meet/show/ect.
I want a supercharger because of the ease of install (doing it myself), lower cost, and I dont want to be bothered with all the issues of turbos (cool down, baking, header install, ect). I remember when you did your DIY, one of you biggest issues was dealing with the headers.
Originally Posted by Modme
The driver side header is a major PITA. There is hardly any room to work with. The hardest part for me was actually getting the heat shield out. The bolts can be removed easily but there is not enough gap for the shield to be pulled out. It took me an hour just rotating and banging on the shield to finally get it out.
There is almost nothing that would sway me to a TT set up (aside from being free). I am ordering a supercharger, just dont know which one yet.
(Again, these are my personal opinions and concerns)
Old Mar 13, 2010 | 11:45 AM
  #62
Modme's Avatar
Modme
Of course you're right. Turbos is a pita to install. But I just wanted to point out some facts for everyone to consider. Many people in the past have asked what is a safe limit for our stock engine, and the answer has always been around 500whp. However, one has to consider that a turboed car is making about 575 hp at the crank to produce 500whp. But for a supercharged 500whp car, the engine might have to generate 676 hp at the crank. The wear and tear will obviously be different.
Dont be misled by only looking at whp.
Old Mar 13, 2010 | 11:48 AM
  #63
Modme's Avatar
Modme
Originally Posted by WhosUrBuddiee
Sorry Modme, but I selected the stage 1 kits from all four kits. The dynos you posted are from Christians stage 2 build, which is more of a 20,000 dollar cost.
Actually,
Here is the thread with stage 1 turbos:
5.5 psi 450wbp
https://www.myg37.com/forums/engine-...-338-rwtq.html
Old Mar 13, 2010 | 11:49 AM
  #64
G37Sam's Avatar
G37Sam
That's a first? What makes you say that?
Old Mar 13, 2010 | 11:57 AM
  #65
G37Sam's Avatar
G37Sam
Actually,
5.5 psi 450wbp
That's very weird out of a stage 1, they did some other car with a stage 2 and at 9 psi that also made around 450whp
https://www.myg37.com/forums/engine-...p-428rwtq.html
Old Mar 13, 2010 | 12:13 PM
  #66
Buddy Revell's Avatar
Buddy Revell
Originally Posted by whiddles
which means for me they are a tie and now it will be the price of install. GTM says 12-14 hours and stillen says 10-12 hours. Which means stillen my cost less for labor over GTM which may make the final cost of each kit the same
A two-hour install time difference will probably run about $200-250. Considering the $900 difference on the kits themselves, you'll still have extra cash for important supporting mods like an oil cooler and gauges.
Old Mar 13, 2010 | 12:26 PM
  #67
Sam@GTM's Avatar
Sam@GTM
Not to add confusion, here is a dyno graph with stage one, MT or AT, with and withou boost controller and of course the gas all will make huge difference in the outcome but this will show at least what stage 1 can do .
Sam
Old Mar 13, 2010 | 12:34 PM
  #68
Modme's Avatar
Modme
Check out the article I posted on page 4.
Old Mar 13, 2010 | 01:04 PM
  #69
G37Sam's Avatar
G37Sam
On the other hand, superchargers require that some of the engine's power be used to drive the supercharger.
You're saying the TT doesn't? Which also requires some of the engines power
I read that article you posted and agree with it, but what you were saying is that a TT would see less bhp for the same whp which I don't agree with. Only drop in hp between those two is due to transmission losses and the supercharger kit has no intervention in that.
Old Mar 13, 2010 | 01:16 PM
  #70
WhosUrBuddiee
I know TT can make alot more power, but that is not a route I want to even consider for myself.
At this point it is either GTM SC or Stillen SC
Old Mar 13, 2010 | 04:00 PM
  #71
Modme's Avatar
Modme
A supercharger uses more hp to power than turbos. How do you explain the fact that turboed engine produces 450whp at 6 psi, but it takes 8 psi for superchargers?
Old Mar 13, 2010 | 05:00 PM
  #72
daveinli's Avatar
daveinli
Stillen was supposed to buy back the Gen 3 CAI's. so if that is the case, it will lower the price somewhat. Need to find out from Stillen.
for the few horsepower you get more from the stillen kit, not worth it, go for the GTM kit, you can get the gains from other areas like the exhaust, remember there test was done with factory exhaust. $ 1000 less for GTM, is a $ 1000 you can spend on repairs when you start breaking other things because of you lead foot.
Old Mar 13, 2010 | 05:03 PM
  #73
Buddy Revell
Or for the extra money you'll save, you can buy supporting mods to help make sure you don't break anything in the first place (oil cooler, clutch, gauges, etc.)
Old Mar 13, 2010 | 07:06 PM
  #74
G37Sam's Avatar
G37Sam
Different compressor trims? On a TT you have two compressors unlike one in a SC. The TT might simply be flowing a little more air in.. Or could have a higher efficiency. And those are just two of the endless factors that could affect your final dyno numbers.
And even if the supercharger does use up more power to spin, it would show in both whp and bhp
Old Mar 13, 2010 | 07:07 PM
  #75
Vu37's Avatar
Vu37
+1, 1k towards my car payment........
