problems with clutch. help fast please!!
Also for $1,400 dollars that a rip! You should buy a hi-perf clutch and if so a flywheel you could get both and installed for around $2,000 - but not at the Stealership.
Tranny warranty is around 50,00 miles 7 years...
Also... if you bought it at 19,000 miles they need to honor it and fix it because that is BS! Guy who had it before you f'ed it up if anything..
im thinking JWT clutch/flywheel for 760 deal. and installed by a friend who owns a shop for 500~
REVIEW, Infinti, Manhasset, bad service
^^ Yep they are Scum Dealership!
After reading that review its no doubt they're the "Don't let the door hit you in the *** on the way out" type of guys.
We should have a Stealership warning list around here to warn new buyers!
Well I can tell you that this forum indexes well in Google so this should come up under reviews.
Notice I added the Keyword at title to help better index this haha!
I would think the master cylinder would be covered under warranty. Failure of the master cylinder is almost certainly a manufacturer defect. Its not a wear item like the clutch plate or flywheel.
it is, it should be. but the dealer INSISTED it was the clutch not the slave cylinder. SO guess what, i either pay 1400 for a clutch+slave cylinder, worst case scenario i wouldnt hold it above them to replace the slave cylinder, and not even replace my clutch. or go to an independant shop who recognizes that its the slave cylinder and just replace that.
This issue is scaring me. My younger brother drove my car and stalled so many times while I was gone for school. He was trying to learn how to drive in it. Don't want to jack your thread with my nonsense though. I hope everything goes well with yours. As others suggested, trying a different dealer could help. God bless
the clutch on my 08 g37 coupe. is acting up. In the middle of driving it, the clutch would only engange half way. Now i parked my car, and i can depress the clutch to start the car, however it wont go into first gear. And if i put it into first gear and start the car, the car turns, but doesnt start. I need help please.
also when the car is off, the clutch only comes up halfway/the engaging point. and i gotta manually pull up the clutch pedal. I need answers or else i cant drive home. Help please!!
