For those that have RPM issues
Old Jan 21, 2010 | 10:44 AM
ucla bruin's Avatar
ucla bruin
I had been experiencing rough RPM fluctuations from the point of annoyance to inconvenience. Whenever I came to a stop and clutch out, the RPM would drop from 700 to 500-600. You'd feel the car shake as if it's about to stall, then it'll come back up to 900 and back down to idle 700. This happened semi-regularly. A few times, I had to stop and go and the car actually stalled. I've also had cases where I'd start the car up and the RPM would just drop and dies.
So after duplicating the problem to the tech at the dealership, I dropped off the car. Picked up the car last night and so far it seems ok. Problem hasn't come back, everything is running smooth.
Apparently they found the intake timing solenoids on both banks stuck. No DTC detected. Both intake timing solenoids were replaced and the oil was changed.
The tech explained to me that they have seen cases with other cars that if you go too long over the recommended interval for oil change, something (magnetic valve timing cover, I think), doesn't adjust and causes similar problem. It was mostly on AT sedans where the owners were not changing the oil. I was the first he's seen with the 6MT though.
I took the car to Cerritos Infiniti to my usual service consultant, April. I've been going to her every time I have an issue. She has always done an excellent job. Strongly recommended.
The tech that worked on my car was Scott, also very nice guy, very knowledgeable.
__________________
Old Jan 21, 2010 | 10:47 AM
Gamedog's Avatar
Gamedog
Sam Rothstein
My car does this too. Pretty annoying like you mentioned. Gonna get mine checked and bring up what you mentioned about the intake timing solenoids.
Keep us updated Daniel-son.
Old Jan 21, 2010 | 10:50 AM
Mike's Avatar
Mike
Good info.
Also good to see Cerritos stepping up their customer satisfaction after Bill Stephens became the GM there.
Old Jan 21, 2010 | 11:04 AM
ucla bruin's Avatar
ucla bruin
Have talked to Phil Tucker, service and parts manager, a few times over the year too. Very nice guy, much better than the last one!
__________________
Old Jan 21, 2010 | 12:33 PM
Mike's Avatar
Mike
Bernie Perry...
Well... Lets just say nobody has anything nice to say about the guy. NOBODY.
He's leading Riverside down the path to failure.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
goredcar
Mar 22, 2016 05:50 PM
redlinernyc
Feb 29, 2016 11:06 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
