12,000 mile engine oil flush
Old Nov 2, 2009 | 08:33 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Pf6KY6rrqYU&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Pf6KY6rrqYU&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Nov 2, 2009 | 11:12 PM
KnoxvilleG37's Avatar
KnoxvilleG37
^^^that's a great video. Exactly my point. Most auto manufacturers (INCLUDING NISSAN!!!!) do NOT recommend engine/transmission flushing due to potential damage to those parts. I would NEVER take another car to Jiffy Screw or an EZ Lube-me-outta-extra-money. PERIOD. Use quality oil with a new filter every 3750 miles and there's NO REASON your engine should need a "flush".....more like flushing cash down the toilet if you ask me.
Old Nov 2, 2009 | 11:30 PM
speedracer g37's Avatar
speedracer g37
i wouldn't think you need an engine flush in any car before 60k.
Old Nov 3, 2009 | 12:27 AM
Wongster's Avatar
Wongster
Back in the days, one of my buddies worked for a major oil change chain. I used to bring in my GS-R, an oil filter and 5 quarts of Mobil 1 Synthetic to have him change it for me. He would always drain the oil, pour in a quart of bulk dino or synthetic blend to flush the engine, put in the new filter and then fill with Mobil 1. Was it necessary? No, but the flush was free so I didn't complain.
Old Nov 3, 2009 | 01:03 AM
BradManUWF's Avatar
BradManUWF
You don't need an engine flush, EVER! A solvent is used to "flush" the engine which is essentially a degreaser. Think about what happens when that solvent degreases your crank and rod bearings and then you start the engine after adding new oil......bad things would happen. Change your oil when the manual says to, and you'll never have to worry about sludge build up.
Old Nov 3, 2009 | 09:46 AM
CHI-TOWN G37's Avatar
CHI-TOWN G37
^Yep. Go flush your colon first before flushing anything on your automobile.
Extended warranties,"The Protector", rustproofing, bird doody treatments and on and on.....
Old Nov 3, 2009 | 09:54 AM
Calgarywinger's Avatar
Calgarywinger
And don't forget, very critical, to have your dealer refill the tires with InfinitAir for only $80...
Old Nov 3, 2009 | 09:58 AM
Heat's Avatar
Heat
This is a scam.....When in doubt, go with your owner's manual.
As long as you change your oil at the recommended intervals, you shouldn't have this problem on a modern car.
Old Nov 3, 2009 | 11:58 PM
BradManUWF's Avatar
BradManUWF
Modern car? Hell, ANY car, except a Kia! How else are 60s muscle cars still around with original engines. Changing your oil, the #1 recommended "engine flush", lol.
Thedbarz
33
Feb 9, 2016 12:05 AM
Zach Stewart
Aug 18, 2015 05:01 PM
cellwoot
Aug 13, 2015 04:27 PM
JakeG37
Aug 2, 2015 12:00 PM
