Help Help please
Old May 16, 2009 | 08:02 PM
VRG37S's Avatar
VRG37S
Help please
I need some help please guys... I just uninstalled my cobb ap and my car has now went into limp mode..The car won't go above 1200 RPMS..... I just took the negative terminal off of my battery to reset the ecu.... Can anyone help me please.... And when i was reflashing my car i didnt unhook the cobb....... Thanks a lot
Old May 16, 2009 | 08:56 PM
jnguyen's Avatar
jnguyen
same thing happen to me. Reinstall Cobb but this time dont save your stock style map then uninstall and you should be on the newest up to date Nissan OEM factory map that was preloaded on Cobb and your car should be fine again
Cobb is so fragile that every little static shock will corrupt the OEM map that you saved so when you uninstall you probably loaded your saved map and it was corrupted
Old May 16, 2009 | 11:18 PM
VRG37S's Avatar
VRG37S
Thanks a lot for your your advice....Anybody else have any ideas.. Thanks again.....
Old May 17, 2009 | 11:52 AM
VRG37S's Avatar
VRG37S
Hey Guys, Well bad news..I reset my ecu overnight and it actually kinda made it worse.. Now my car starts up and then dies..I have no throttle at all.... I hooked up my ap to reset the ecu and that did nothing..I'm getting the code po605...ECU/ECM...Anybody have any other ideas..If not the car is getting towed to the dealer this week...Man im soooo upset....
Old May 17, 2009 | 11:57 AM
SOLISIMO's Avatar
SOLISIMO
wait and talk to cobb tom. I think the dealer will blame everything on the cobb and your screwed! I keep hearing nothing positive about these guys
Old May 17, 2009 | 04:39 PM
jnguyen's Avatar
jnguyen
Make sure your intake sensors are in tight then do my method and it should fix it man. Cause i had got the same code.
ECM means electronic Control module which basically is your ECU and basically its a bad reflash. happen to me then some other guy on the forum and i told him what to do and he said it fixed it so 8/10 its my problem too
do my method first before you get it towed man! make sure you update cobb too so u can have the most up to date nissan map after my method. KEEP ME UPDATED!
Old May 18, 2009 | 01:15 AM
VRG37S's Avatar
VRG37S
Thanks sooo much for giving me advice... I'm going to try this tomorrow and see what results I get.....
Old May 18, 2009 | 04:30 AM
Blackjack's Avatar
Blackjack
Best of Luck, Jake! Keep us updated.
Old May 18, 2009 | 04:41 AM
jnguyen's Avatar
jnguyen
PM ya just in case ya missed it! I suggest you really try it though! worst case scenario is you bring to dealership which i highly doubt plus you would bring it there anyway if you dont try.
Old May 18, 2009 | 05:01 AM
BradManUWF's Avatar
BradManUWF
I bought a cobb ap but haven't used it yet since I'm on deployment. Seeing all these negative stories people are having is making me not want to use it at all
Old May 18, 2009 | 11:45 AM
jnguyen's Avatar
jnguyen
not really alot of negative. Just a few people have problem with uninstalling but its not even a big problem cause you still get a new oem map update i believe. that is what cobb told me
Old May 18, 2009 | 12:43 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
negatives have been USER ERROR
Old May 18, 2009 | 03:46 PM
ufo's Avatar
ufo
MaxToTheG37, I'm sorry to change the subject here, but I just noticed you have 12,278 posts to this forum?? And that's roughly over an 18 month period?? That is something like 25 posts per day, every day... Do you have a girlfriend (or boyfriend if applicable) ??
Old May 18, 2009 | 06:49 PM
jnguyen's Avatar
jnguyen
Anyway any update jake? Been keeping a eye on this thread so I can try help you as much as possible
Old May 18, 2009 | 11:56 PM
ufo's Avatar
ufo
^ not taking a shot just a little humor my friend, if I could offer any help on this I would
