Weird Idle When Started Up
Old Jan 7, 2009 | 09:20 AM
alofoque's Avatar
alofoque
I'm aware that when the car is started cold its going to have a idle at around 1.5K RPM untill wamed up. Lately the car has been idling at around 2K and it stays up there even after the temp needle is at half way(reg operating temp). Also while driving with the car with the high idle the rpms seem to stay up and drop very very slowly while the car is in neutral and stopped. Anyone else experience this problem?
Old Jan 7, 2009 | 09:24 AM
aliiin's Avatar
aliiin
BMW Defector
where do you live? how long is the high rpm occuring for until it finally drops? what is the outside temp?
Old Jan 7, 2009 | 09:31 AM
Xcalibur's Avatar
Xcalibur
I know on the 6MTs its higher idle. Mine gets up there too on cold starts.
In My opinion its too high an idle for a cold start.
Old Jan 7, 2009 | 09:37 AM
alofoque's Avatar
alofoque
Yea it ahs always been at 1.5K no more then that and once the temp needles moves up a bit it drops to normal. I'ts going up to 2+K and staying up there even after the needle is at halfway.
Old Jan 7, 2009 | 10:37 AM
chasemyaccord's Avatar
chasemyaccord
You sure you're not resting your foot on the accelerator?
I think the highest I've seen mine idle on a cold start is about 1800. I wait until it hits about 1100 before I go.
I do garage my car, so it hasn't been fully exposed to the elements on a really cold day.
Old Jan 7, 2009 | 11:24 AM
Callaway's Avatar
Callaway
Arm flailing tube man
go to your dealership and mention this TSB. I had the same exact issue and they reflashed my ECU. Problem solved.
https://www.myg37.com/forums/tsb-tec...g-braking.html
edit: nevermind, this is for AT only.
Old Jan 7, 2009 | 11:38 AM
BigDan727's Avatar
BigDan727
Hm mine gets to about 2k on REALLY cold start ups
But a hanging idle could be a few things
(Dirty MAF, Bad Ground someware)
Take it to the dealer and see what they say
Old Jan 7, 2009 | 12:10 PM
After it warms up to near operating temp and stays high, does it drop to 700-800 RPM after you press the accelerator one time? Have you checked your oil level?
misc
29
May 24, 2023 03:57 PM
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
vamarris
Dec 9, 2018 11:10 AM
Prometheus
Nov 9, 2015 01:23 PM
G37sPhoton
Oct 4, 2015 11:08 PM
