Dyno'd My Car
Old Dec 15, 2008 | 07:47 PM
Garyv01's Avatar
Garyv01
Dyno'd My Car
So today I decided to dyno my car. I had it done at Speedworld in Baldwin, NY Place was pretty clean and cost $75 for 3 runs. I thought that was reasonable since some shops i called were charging $150.
A few weeks ago I installed a Fast intentions Catback exhaust and about 3 days ago got the Cobb AP. I'm currently running stage 2. After the tune i felt the car pull much stronger so i was curious to see how much it was putting down. I will post some vids later. Anyways here are the numbers:
http://i162.photobucket.com/albums/t...v01/scan-1.jpg
Old Dec 15, 2008 | 07:56 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
can you explain each run?
Old Dec 15, 2008 | 08:03 PM
Garyv01's Avatar
Garyv01
what would you like me to explain?
The run that is highlited in red was the 3rd run, which was the best run.
He ended up revving to around 8000 rpm's, whereas the other's were performed up to 7500 rpm
Old Dec 15, 2008 | 08:09 PM
MaxToTheG37
well the middle one gained 10hp. so i was wondering if you added a stage on your AP or what?
Was your point of this dyno to see what you were at total? or were you testing the Cobb AP out? thats what I was wondering...
Old Dec 15, 2008 | 08:12 PM
Garyv01's Avatar
Garyv01
oo i see..no basically i was just testing to see how much hp i have gained overall with the cobb AP and the fast intentions catback... one of the runs were done in 3rd gear and the other 2 in 4th gear... but the run that maxed at 292hp was revved higher than the other 2...i'm assuming that's were the power gain is coming from
Old Dec 15, 2008 | 08:21 PM
G37Sam's Avatar
G37Sam
i think you just wasted 75 bux man lol
you felt gains so you went to check.. what did u conclude? for all you know your car couldve been putting 300rwhp and now doing 292
Old Dec 15, 2008 | 08:26 PM
Garyv01's Avatar
Garyv01
? def not
A dyno is a dyno and i wanted to see how much power is really putting down.
Afterall, why do people get dyno's done at all then according to your theory.
And i paid 50 cuz i got a discount
Old Dec 15, 2008 | 08:27 PM
MaxToTheG37
Good Job bro... now you have a baseline... next time we can see what new mods makes hp wise...
Old Dec 15, 2008 | 08:30 PM
Garyv01's Avatar
Garyv01
Thx man...yef def....maybe some HFC's in the near future
Old Dec 15, 2008 | 08:57 PM
G37Sam's Avatar
G37Sam
Originally Posted by Garyv01
? def not
local shop asked me for 220$ for a dyno.. wanted to do a before and after on my FI setup.. he gave me a 350$ invoice so im like screw it! butt dyno is for free
i'm just saying for 50 bux a session i would've done endless before and afters! and its what you should've done to figure out the true gains
Old Dec 15, 2008 | 09:05 PM
Garyv01's Avatar
Garyv01
what's the point of doing a b4 and after?
I know for a fact a stock G37 puts down around 265hp stock
So there's your before and after 265hp--->292hp
Old Dec 15, 2008 | 09:13 PM
bfranks's Avatar
bfranks
That's slightly flawed logic. But since the dyno showed what you wanted to see, and you got a good price on it that's all that matters I guess .
Edit: And now, having actually looked at the dyno....that's an interesting torque range for 3 identical runs.....
Old Dec 15, 2008 | 09:18 PM
TJ_coupe's Avatar
TJ_coupe
thanks for the numbers, sounds like after I get my intake, the access port is next on my to-do-list.
Old Dec 15, 2008 | 09:19 PM
cvt's Avatar
cvt
? def not
you get a dyno to get the delta...so when you mod you have a baseline...
Old Dec 15, 2008 | 09:41 PM
G37Sam's Avatar
G37Sam
exactly, in english, you want to know how much you gained on a hot humid day you'll get a different number than on a cold unhumid one.. and it does make a difference (265whp sounds low I've seen 280's around)
