So I Got A New Transmission and....
So I have about 7500 miles on my car and I had grinding issues with 3rd and 5th gear... regular driving nothing crazy... I would have the clutch depressed all the way to the floor and I felt grinding... So when I got my 7500 maintenance check up, I asked them about it, and the mechanic confirmed a transmission problem... He then later needed me to bring my car back in for diagnosis. My AFS light also kept blinking and I asked them about that too...After an hour or so, they diagnosed the AFS problem as an AFS actuator problem... so they ordered the part and said for me to reschedule to fix it.
I went back there ASAP, 7:30 a.m. after thanksgiving, brought it there, and they said they'd need my car for 3 days because they had to call infiniti corporate and whatnot. My AFS actuator also had not come in yet.
So, I call them today and they said that I get a brand new transmission because there was problems with my synchronizers. They are sending the old one back to infiniti. And the AFS actuator still has not come in yet... So they said it'll probably be the end of this week until I get my car back....
So my question is, any of you have to replace a tranny yet?
Can you post a copy of the work done and problem?
__________________
__________________
01 afs light flashes at times- sop here. See history
code 82504 found see ro 00714 internal failure of swivel actuat lamp
lh repl left headlamp assy erased code test drive
parts-
housing assy - head-26075-jl01b
02 c/notes grinding into 3rd and 5th. See history. Advise.
Found 5th-6th coupling sleeve teeth broken off 3rd synchronizer cone
cracked & 3rd counter gear locking teeth see note
parts-
transmission-32010-jk40b
75w-85 manual trans-999mp-mtf00p
ls
line o2 deformed metal and bronze particles found in tranmission case replaced m/t assy test drive ok
parts-
parts-
ls
just talk to them...they let me drive a loaner when i was 20 waiting for my car to be shipped from cali to tx...that was with g35c tho..crest infiniti..had it for a good week...did a road in that piece around tx..hahha
what's up with this shiz? i dropped my car off today AGAIN after another 1 k miles and i feel like 3rd gear has a problem. dunno what the deal is... anyone chime in?
car is at 9400 miles now
I guess your giving the car bad luck. JK. hmm I don't really have grinding right now cause my car is pretty new but keeping on taking it to the dealer till they have the problem fixed.
