G37 stick shift conversion
I'm not sure exactly, but it would be VERY expensive. You would have to replace the entire tranny; sticks and autos work entirely differently. You would probably be better off selling and buying a stick.
You would need to change ALOT, the transmission, the pedals, the ECU would need to be changed, the E-brake would need to be moved, the dash would need to be changed so it dsnt read out P-R-N-D.
There was a company doing this for the G35/350z's, but it costs 8,000$, so I can only imagine what it would cost for this car.
It would be cheaper to trade the car in and buy a 6MT.
Unless you can find a donor car and just do a part for part swap, selling all the automatic parts, and anything else that is salvagable on the donor...
I don't see you coming out ahead of trading in on this one.
Yes you can do this but is it the best option? NO! Your best bet is to trade out or have a donor car because the parts might be expensive.........but do not listen to what anybody has to say just do your research first then act.
A friend of mine did the same when he converted his 02 maxima from auto to stick.
