For 6MT owners - Skipping 5th...
I still don't get the reason of you guys making jokes everytime you have a chance about us driving 5AT.
Hey, if you are lucky enough to not drive in a 1 hour-5 mph-bumper to bumper traffic each way to get to your work and home, and lucky enough to have a wife that drives manual then GREAT for you.
, but for the rest of us thar are not that lucky we got this great car and are very happy driving it in 5AT, so stop bad taste jokes, after all, is the same car isn't it?, Last time I checked this one came with 330HP also...
Haha JK
not using a clutch at all sounds insane - lol
I see people at the track "powershift" - ie - keep right foot pegged and simply shift gears with the clutch as fast as possible. Even that treatment is iffy on a driveline if not executed perfectly, and can easily lead to a mechanical overrev if you miss the gear altogether
personally, from what I've seen, powershifting can increase mph, especially on any type of 3-4 shift....you do not want the nose dropping at those speeds as you will surely drain off mph trap. but it is not as huge a variant as alot of people believe on elapsed time capability. You can still execute very low et runs for a given car with "granny" shifted shifts, as long as they're crisp and near the rpm limit. Drag racing still boils down to a 60ft time/launch for the most part....shifting down track, especially 1000 feet out is a far second place category in regards to et's
100% grandmama shifting right here.
http://www.youtube.com/watch?v=RmjKNF47ZME
what makes going from 1-2 not powermatic compare to 5-6? it sounds crazy not to use the clutch to shift.
What makes 5th/6th more problematic to shift into w/o the clutch is the fact that they have different/inferior synchros than the lower gears.
If the synchros are making any difference then you are not matching revs perfectly enough and need to stop trying to shift w/o the clutch. You're simply killing the synchros on the lower gears and luckily they can handle it (for now).
For all those that want to know why you are grinding in high gears with a clutchless shift.
1st, 2nd, and 3rd gears all have triple cone syncros
4th is a double cone syncro
5th and 6th are single cone syncros, which is why it is harder to shift without grinding.
If you want to know why this matters, do a search as I explained it in great detail on another post.
