Stillen Crank Pulley
Old Sep 3, 2008 | 12:33 AM
  #181
KahnQuistador's Avatar
KahnQuistador
Originally Posted by neverbonestock
I had the same issue on my z and the shop just heated up the bolt and it came right off ..
Stop making sense!!!!!!!
I'm not used to it.
A little heat in the right spot and a pneumatic wrench ought to do it.
Edit - heat the nut, not the bolt.
Old Sep 3, 2008 | 12:50 AM
  #182
NeverBoneStock's Avatar
NeverBoneStock
I'm not used to it.
Well at least you know what im talking about ..
Old Sep 3, 2008 | 03:25 AM
  #183
DanMardik's Avatar
DanMardik
To bad we never got the gains tonight :*(
Old Sep 3, 2008 | 03:50 AM
  #184
chucky's Avatar
chucky
special tool
In the maint. manual there's a special tool to lock the flywheel in place.This will make the job a lot easier. I'm installing mine this week along with JWT clutch and flywheel I'll post after the install. I don't have the tool but since I'm doing the other stuff I'll come up with something to lock the flywheel in place.
Old Sep 3, 2008 | 02:00 PM
  #185
DanMardik's Avatar
DanMardik
where are the results? waaaaaaaaa
Old Sep 3, 2008 | 02:06 PM
  #186
TerribleONE453's Avatar
TerribleONE453
damn AZ...
Old Sep 3, 2008 | 04:20 PM
  #187
DanMardik's Avatar
DanMardik
Old Sep 3, 2008 | 05:30 PM
  #188
rossab's Avatar
rossab
I want to order one of these if you got gains... hurry up, I'm putting in my order for everything else now
Old Sep 3, 2008 | 05:53 PM
  #189
AZg37's Avatar
AZg37
I'm sorry for the delays, I started to scan all my dyno's from the past 3 months or so, I have done 5 total, but my scanner crapped out after the first 2 were scanned. I made an entire new post on all my results, but only have 2 of the 5 graphs up. I'll put the other 3 up when I get paid again and can afford a scanner. Here is my post on my gains, for ALL my mods so for:
https://www.myg37.com/forums/showthr...22#post2412922
The UR pulley gained 5 HP for me after an ecu reset and 200 to 250 mile break in period. The JWT pop-charger actually yeilded an impressive 7 HP even with all the other mods. Once again, sorry for the delay, and lack of graphs, but they'll be up shortly.
Don't flame me, I'm trying my hardest not to have my dyno thread be a FAIL
Old Sep 3, 2008 | 05:58 PM
  #190
Hpauto's Avatar
Hpauto
Good gain on that pulley, cant beat the gains for the dollar amount, thats for sure. I need to have UR ship me more of these
Old Sep 3, 2008 | 11:23 PM
  #191
KahnQuistador
Well, from Stillen:
"100% of the power gains from the stock diameter pulleys comes only from weight reduction versus the factory crank pulley. The reduced weight allows for more power transfer to the drive wheels. Any of our accessory pulleys that are listed individually can be used in any combination with our stock diameter crank pulley or purchased as a set. The stock diameter crank pulleys are available in polished finish only."
I saw no info on the weight difference so the answer remains a mystery, physics-wise. No argument with the HP claim either considering the math involved. I don't push pencils much anymore. Good habit for students, though.
Is there a before/after dyno out there for just adding the pulley?
Didn't I post about this earlier?
Not dissing the mod, just questioning the cost/benefit ratio. This mod should be the last you make to get that last fraction of power after everything else is done unless you choose to underdrive the system. And that's not a wise decision.
JMHO, of course. Wait... JMO. I'm not too humble. But you knew that.
Old Sep 9, 2008 | 03:50 PM
  #192
Buddy Revell's Avatar
Buddy Revell
Originally Posted by AZg37
...UR is claiming there is a "break in" period with this mod, i guess the ecu doesn't recognize the new pulley right away. They say after a couple thousand miles we should see 12-16 HP gain from this thing!!! Woot woot!!
Old pulley is like 8.5 lbs and new one is 1.5lbs. i'm super excited to get this thing on!!
From UR's site: "Weight reduction is how we are able to increase Horsepower! Each pound of weight removed from the crankshaft is worth approximately 2.7HP and the gains jump even more dramatically with forced induction, nitrous and variable valve timing."
I wanted to get some insight from guys at UpRev (a premier Nissan tuner) about crank pulleys and their effect on HP. First of all, does the ECU need to adjust to a lighter crank pulley? Second, does having variable valve timing or forced induction improve the amount of power someone can get from a crank pulley? Finally, if horsepower gains aren't shown from a lighter pulley, is performance still improved due to the engine revving faster?
Old Sep 9, 2008 | 03:54 PM
  #193
Skyline-LEXY's Avatar
Skyline-LEXY
^ +1
Old Sep 9, 2008 | 04:07 PM
  #194
TerribleONE453
also curious about those questions... ^
Old Sep 9, 2008 | 04:12 PM
  #195
Lastchance's Avatar
Lastchance
Finally had my pulley installed at Stillen. Car seems to have a tad more zip now.
