Octane boosters!
Old Jul 9, 2008 | 09:30 PM
GiGGaplease's Avatar
GiGGaplease
Originally Posted by Kidcane
You guys must be in Cali cause its 93 all day here in FL.
all day and every day. theres 92 here too, have no clue why. didnt know there were even numbers gas rating.
Old Aug 2, 2008 | 08:30 PM
icel0rd's Avatar
icel0rd
Why would anyone bother trying to increase the octane rating? The higher the octane, the more stable the fuel is at higher compression, which prevents pre-detonation, engine damage, and wasted fuel, so putting higher octane fuel in your car than it's designed for or it is tuned for sounds like a waste of time.
Also, assuming it is true that temps drop in your exhaust from a higher octane fuel, that would also theoretically reduce the efficiency of your cat, wouldn't it? Your cat needs the heat to help burn up the crap that will get you a "fail" for emissions.... Also, again assuming there is any truth to the lower temps in exhaust, that probably means might mean that your engine is wasting more fuel and burning less since heat is a byproduct of the combustion of your air/fuel mix. Less heat might mean less was burned.... and I could go on and on..
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
deky_
Sep 12, 2015 11:02 AM
BlackG37Coupe
Aug 12, 2010 12:23 AM
Serbiasrt8
Video Share
16
Jan 26, 2009 06:47 PM
