service engine light at 800 miles?
Old Jul 2, 2008 | 05:35 AM
D-Loc_-'s Avatar
D-Loc_-
good or bad thing?
its been on for like 2 days now. i was hoping it would go away.
Old Jul 2, 2008 | 07:06 AM
bboysteele's Avatar
bboysteele
Depends! Take it to the shop.
Old Jul 2, 2008 | 09:16 AM
aliiin's Avatar
aliiin
BMW Defector
better take it to the shop, better safe than sorry
Old Jul 2, 2008 | 10:32 AM
nogoodname's Avatar
nogoodname
get it scanned
Old Jul 2, 2008 | 10:37 AM
Gamedog's Avatar
Gamedog
Sam Rothstein
It's them 22's throwing off the calibration of your tranny and speedometer...
Just Kidding man I don't know But yeah like everyone else says, either get it scanned or take that bad boy in....
Old Jul 2, 2008 | 10:41 AM
splatt's Avatar
splatt
I've had this twice and both times it was the gas cap. The first time I let the tank get really low before filling and it came on for a few days.
The last time it came on a few days after I filled so I took it to the dealer. They said the cap was loose. My bad.
Fill it up and make sure the cap is several clicks tight. Even then it can take a while for the light to go off.
I'd get it looked at anyway.
Old Jul 2, 2008 | 11:15 AM
Achilles's Avatar
Achilles
Take it to the dealer, get your loaner and off you go!!!!
Old Jul 2, 2008 | 11:19 AM
volnedan's Avatar
volnedan
this has happened to me twice, and the first time they said it was a loose gas cap. however, it was on half tank and it didn't fix the issue.
few hours after i took it home from dealer it came back on, without touching the gas cap. took it back the next day and they still have my car. this was a week ago, and they deemed it an "EVAP system leak".
Just take it in. I've been driving the loaner G35x for a week now, and its quite nice. Especially not putting miles on my car (lease~15k/yr)
Old Jul 2, 2008 | 11:22 AM
+1 Any time you get a CEL always check and tighten the gas cap first. Drive a few miles and if that's the issue it will go away. Your next check should be any emissions control (O2)sensors. Check for loose connections. Then I'd say take it in or check it yourself with a code reader to see exactly what code it's throwing. You can get this done at many auto parts stores as well without having to go to the dealer (like in case you have exhaust mods that you don't want your dealership to know about ).
Old Jul 2, 2008 | 02:18 PM
Graham's Avatar
Graham
Sounds like probably just a gas cap. unfortunately until infiniti resets your car the CEL will be on, just got to make sure you click the cap a couple extra times than you would think.
Old Jul 2, 2008 | 02:47 PM
RIDEwithG's Avatar
RIDEwithG
This happened to me during test drive. LOL. Definitely a good way to sell a car!
Old Jul 2, 2008 | 02:57 PM
notalk's Avatar
notalk
"Any time you get a CEL always check and tighten the gas cap first. Drive a few miles and if that's the issue it will go away."
"Sounds like probably just a gas cap. unfortunately until infiniti resets your car the CEL will be on"
Both of these can not be correct.
Actually, the first is closer, while the second is false. The car is programmed, as are most of today's cars, to keep the light on until the symptom has been removed and the car makes three trouble-free trips. A trouble-free trip does not mean once around the block, it means actually driving the car a reasonable distance.
Old Jul 2, 2008 | 03:45 PM
Graham's Avatar
Graham
I had the light on for multiple fillings, the light didn't go off until I had my oil changed and they cleared the code. You can click the cap as much as you want and that light isn't going to go off once its on due to that reason.
Old Jul 2, 2008 | 05:51 PM
PureNick's Avatar
PureNick
Will BAD gas throw this on?
Old Jul 2, 2008 | 06:29 PM
Graham's Avatar
Graham
no, the octance level won't cause a CEL, but obviously crap in your gas can cause problems. So don't be filling up with MX pre-mix or anything.
