Unichip or other piggyback chip
Old May 27, 2008 | 10:17 PM
The1andOnly's Avatar
The1andOnly
^Yes. That's the good thing about a piggy back ecu. You can cnage the settings when you get new mods or even test out different settings to see which one you like, and you can go back and forth bewtween settings.
Old May 27, 2008 | 11:48 PM
LeonC626's Avatar
LeonC626
so are there plans for piggybacks for our G out there yet?
Old May 27, 2008 | 11:56 PM
The1andOnly
Yes. The one most are anticipating is the Cobb access port.
Old May 28, 2008 | 12:41 AM
speedracer g37's Avatar
speedracer g37
...and you can take it off or reset it to factory settings before you take your car in for service.
Old May 28, 2008 | 01:19 AM
The1andOnly
^+1.
Old Jun 9, 2008 | 09:17 PM
Chebosto's Avatar
Chebosto
Originally Posted by vinnys coupe
isnt the technosquare ecu upgrade similiar to the chip? or are they both two diff things, if so can u install both.
i think there the same just trieng to make sure
There is a reflash, which is over-writing the OEM program with a modified program. Typically will need to be reprogrammed when large air-induction-type modifications that alter AFR is added to the vehicle (plenum, or high flow cats, or intakes). Catbacks, or exhausts dont change the tune much. nor do sparkplug or grounding wires for that matter...
And there are piggy backs. which are 3rd party add-ons that 'intercept' signals from the car's sensors, and substitute with their own values into the car's ECU try to fool it into thinking that the sensors are doing something differently. Majority of the time it works, until the ECU tries to dial back and or change your settings.
the best bet for those that will be changing your engine modifications frequently (since this is the g37 crowd, i'll say not often) is to reflash the stock computer to a new 'baseline', and add a piggyback to allow full user customization.
not all piggy backs are created equal. not all reflashes are the same.. it comes down to, how good the tuner is at knowing the limitations of the engine and what and where to modify the fuel/timing maps.
if you think you can do better than a tune shop, then more power to you! but for the majority of the population that wants a set it and forget it mentality, there are many commercial off the self systems that can be purchased, however currently available for the G37 that is pretty slim pickings.
Old Jun 10, 2008 | 01:27 PM
JanSolo's Avatar
JanSolo
Originally Posted by Callaway
The piggyback chips for turbo-charged cars give you amazing gains with little or no other mods mainly because they can alter the factory boost settings. N/A motors don't have that advantage so any chip in conjunction with N/A mods will still leave you dissapointed if you are comparing the gains to a chipped 335. IMHO of course.
You mean it modifies boost, timing and afr. Anyone can alter boost with an mbc or ebc, but it is the combination of all 3 that make real power differences.
jfisher
Feb 16, 2016 09:57 AM
Upscale Speed
Dec 24, 2015 12:00 PM
NeverBoneStock
Dec 16, 2015 01:50 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Cmedlin96
Sep 20, 2015 11:09 PM
