Supercharger vs Turbocharger
#31
if you drive a car with alittle respect and you dont drive it like you stole and dont push it to its limits everyday then it will hold up for a long time as long as its tuned right as well... i know guys that have ahd TT on G35/350Z and have had them for 20,000 plus miles and dont have any makor problems, especially with internals
#32
Even conserative driving still stresses the engine, even without a TT setup. You may run fine for 10k or 20k, but you may be causing premature wear of internals. We just dont know. I would push your shop to break down the engine after it has a good number of TT miles down, just to make sure everything looks good.
#33
^^^That might be too expensive/time consuming to do, but a regular compression check or leak down test to see how well the engine is holding up to the boost may be a more convenient alternative.
#37
but the high cost and all the extra attention needed doesn't appeal to me
I thought that one of the advantages of a twin Turbo over a turbo was there were little to no spool up time. Is that right or myth. Also, with the G35/350z how well did the TT kits hold up to excessive heat as that has always been a con to a turbo as it uses the hot exhaust fumes to drive the forced induction.
a few sequential turbo cars offered the option of two different sized turbos to eliminate lag. the 03-97 rx7 tt, maserati biturbo, late 80 porsche ruff turbos, etc. the small turbo would spool up quickly and provide low end boost and the larger turbo would kick afterwards with more punch. this was supposed to eliminate the trade off between larger turbos that offered more power and smaller turbos that eliminated lag.
as for the g's and z's there are a bunch of blown motors on driver from the early turbos. i've seen some recent threads with rods coming out of the side of the block from too much boost. and as far as the heat, i don't think that was an issue or ever has been. i'm not quite sure about the question you're asking, but heatwise, the main problem turbos have is the coking (frying the oil) that occurs on the turbos internals.
#38
and that is why they have oil coolers to keep that from happening(which one will eventually be developed for my car) but know i have not read anything eitherabout heat being a problem in the g35/350z.. the only problem is the rods(to smal) and the rod bolts are not strong enough so about 400whp or so they start to fail... far as the trans they are extremely tuff. the clutch is a different story, will need to get a better one
#39
Yea a main problem of turbos is it may cause your car to burn oil depending on how the turbo is cooled... also bigger turbos will hold boost in higher RPMs and lag more obviously because it takes more exhaust air to spool them... smaller turbos give you better throttle response but dont fall off in the upper RPM range... For auto Xing a smaller turbo set up is usually better because you wont all of a sudden hit high boost and spin out ect.... Personally i think a TT is manageable for a DD IMO... because i am used to driving turbo cars although i can say they are not for everyone. Superchargers are easier to deal with but i would not spend my money on oen...
#40
have u guys heard the engine of a merc slr during acceleration? that's what im hoping to make my g37 sound like. i believe that the slr is supercharged but tt wouldnt be a bad alternative.
#41
Thanks for the info about the different sized turbos spooling effectivness. I'm looking to only get around the 400-450RWHP mark so time will tell what the best option is. In the interim, I'm probably going to get HFC, Injen Intake, and Exhaust. Also price and maintanence is important with FI. I'm intending to have the G paid off in two years, so then is the time I will be making my determination on FI.
#42
well... if you ARE planning on going FI you might want to hold off on buying the intake since it will not work with a front mount intercooler set up... unless you are willing to take a little bit of a hit on it... Same with the HFCs because you will need to switch to down pipes... Your WHP all depends your tune... you could even go with a small efficient turbo and hit that no problem... Or larger turbos and run lower boost but you will lag more... but that also gives you the option to push more of course. The biggest problem with our cars now is there is nothing to tune them with so you will need the HKS standalone unit... which equals big bucks....
#43
I wonder...when it comes to engine management, does Technosquare have the capability to reflash the ECU and tune it to work with a custom turbo system, larger injectors, upgraded fuel pump, etc.?
gammamotors
44
12-31-2015 12:48 AM
coupe, g35, g37, g37s, infiniti, install, myg37, supercharge, supercharger, turbo, turbocharge, turbocharger, twin, vortech
