Shifting Questions...
Old Apr 14, 2008 | 09:12 PM
  #31
GiGGaplease's Avatar
GiGGaplease
Originally Posted by vINCe_Inc
i dont believe there is any justification to this comment in my opinion, i say that because your engien is capable of reving to 6k, so regardless of what gear it is matted to, as long as its within its rev range, it should be okay.
again, do not quote my statement. i was talking out of my ****.
Old Apr 15, 2008 | 12:20 AM
  #32
DetroitG37Joe's Avatar
DetroitG37Joe
When conserving fuel I shift at about 2.25k....in fact the shift from 1st to 2nd at about 2k since it feels like it requires less for a lug free shift. Our cars have enough torque at the low end to shift into 2nd at a 5mph+ roll so sometimes i keep the clutch partially engaged after starting in 1st and then engage it again right away at 2k for the shift into second. sounds weird but if you try it you'll see it's pretty compatible with the car.
reason i do that is because higher rpm shifts from 1 to 2 are usually jerkier if you are relaxed and clutching slower. its just my n00b experience.
Old Apr 24, 2008 | 05:33 PM
  #33
blackfunk's Avatar
blackfunk
The issue here my friends is tourque. In a higher gear with all things being equal with such low (relativly) rpm's the engine is no where near its prefered operating cycle. It will work from just about any gear just not up to its full potential. To lose the shudders try giving a little, which is ideal. AKA Heel, toe shifting. But what do I know, I've never driven stick in my life.
Old Apr 24, 2008 | 08:21 PM
  #34
TerribleONE453's Avatar
TerribleONE453
hahah.. ^ honestly if your trying to conserve gas and such you can go all the way up to 3500-4k just dont do it quickly...
37
Oct 17, 2020 11:12 AM
Jonesmeister11
Sep 27, 2015 08:28 PM
Sep 25, 2015 01:38 PM
r0cketm0nkey
Sep 19, 2015 11:10 PM
IrishMike
Sep 16, 2015 07:07 PM
