5AT shifting question?
Old Mar 8, 2008 | 10:38 AM
en-em's Avatar
en-em
I've noticed that when I start the car and just start driving in DS mode the shifts from 2nd to 3rd are quite rough. The shift is not very smooth and feels more like the jolt you feel in a manual when you're racing and hard accelerating quickly through the gears. This happens on normal SLOW driving like in a residential area kind of driving. Is this normal? When the car does warm up about after 10-15 minutes of driving, it gets smoother and more fluid. It is only from 2nd to 3rd gear though.
BTW, I got that stupid baffle problem in the exhaust and the G sounds like crap now!!!
Old Mar 8, 2008 | 11:00 AM
iko's Avatar
iko
this is normal. downshift rev matching
Old Mar 8, 2008 | 12:00 PM
cartman13's Avatar
cartman13
I'd just say for slow driving I would use D instead of Ds. I've found that it makes rough shifts when its around 3k rpm. When its cold the engine probably idles a bit higher than normal. Hence the little jerk.
I'm not sure what was meant by rev matching as that only occurs on downshifts. Not upshifts.
After it warms up try doing a manual shift right around 3k rpm. You'll probably feel the same jerk.
Old Mar 8, 2008 | 03:35 PM
iko's Avatar
iko
^^ good point, guess I didn't read the thread right. I only feel 'rough' downshifts. Never a problem upshifting.
Old Mar 11, 2008 | 12:38 PM
Carolina_g37's Avatar
Carolina_g37
Lol. DS is what it is... Sport mode. The revs will be higher, the shifting will be much more pronounced, this mode basically makes your car a bit more aggressive.
Old Mar 11, 2008 | 12:51 PM
LAZY TURBO's Avatar
LAZY TURBO
the car hasnt warmed up yet, it happens to me all the time.
OneSickBlackG
Jan 6, 2016 08:49 AM
z_spec
Sep 17, 2015 11:49 AM
claudiohv
Sep 17, 2015 01:43 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
inspector94
Sep 8, 2015 12:57 PM
