Clutch sounds like a diesel
Old Jul 3, 2008 | 02:14 PM
  #31
DetroitG37Joe's Avatar
DetroitG37Joe
Originally Posted by Tarshi
I tried another thing.
1. Keep about 3,000rpm at neutral, not engage crutch.
2. Then engage the crutch, drop immediately about 200rpm. also noise too.
Is it normal?
by disengage u mean not have pushed in, and by engage u mean pushed in, correct? some people look at this differently, just makin sure cause I am gonna try it.
Old Jul 3, 2008 | 04:08 PM
  #32
teedough's Avatar
teedough
HEy guys I got a call from my friend. His friend is a mechanic and he worked on G35s and 350z. He has taken apart transmissions and stuff. The rattling noise comes from a metal piece that you are able to move with your hand. That piece just rattles against the transmission.
Old Jul 3, 2008 | 04:15 PM
  #33
TomG37's Avatar
TomG37
I'm a first time 6MT driver, but I think my car may also be making these noises.
I thought it was just the fact that I'm still learning, but it sounds more like the noises everyone has.
Old Jul 3, 2008 | 04:59 PM
  #34
Tarshi's Avatar
Tarshi
Sorry make you confuse,
park the car. (not run)
Disengage: pushed in,
Engage: Not pushed in
Old Jul 3, 2008 | 05:16 PM
  #35
heff's Avatar
heff
Originally Posted by 7o7G37s
Dude i have the same problem .. my first gear sounds like **** from 1000 rpm to 3000 rpm sounds like im super charged haha... but sounds messed up in a way .. i went to the dealer and they said the same thing they said it runs good and they dont see nothin wrong with it . i show aamco experts on transmissions and they said its my clutch . i beat my car up right when i got out the lot. is yours manual
ah man i thought i was the only one , but sometimes mine kidna sounds like a BOV (which is kinda cool) but mostly worries me !
Old Jul 3, 2008 | 07:09 PM
  #36
TomG37's Avatar
TomG37
Okay, I just pulled the car into the garage, I heard a weird noise so I pushed down the clutch, and the noise was gone. My car is defn making the chatter noise that everyone is talking about.
It also makes the noise VERY loud when I turn the car off when it is in N.
Old Jul 4, 2008 | 07:03 AM
  #37
PureNick's Avatar
PureNick
Going in Monday to have them take a look at it.
For all you socal guys, i'm going to Infiniti of Thousand Oaks. If I have success, I suggest going there and swamping them.
Old Jul 4, 2008 | 05:22 PM
  #38
heff's Avatar
heff
sweet please keep us informed!
Old Jul 4, 2008 | 07:43 PM
  #39
teedough's Avatar
teedough
https://www.myg37.com/forums/showthr...92#post2373592
Originally Posted by Blue Slate 6MT
haha dam teedo you're fast i barely called you, but to clear things up let me explain it a bit.
My friend has done everything you can imagine to a G35 and 350Z, supercharge, turbo, auto to manual, you name it hes done it.
The rattle comes from the flywheel because it is a 2 piece design. The 2nd piece of the flywheel is what is making the noise. So when the clutch pedal is pushed down the pressure plate will push the two pieces together, therefore eliminating the rattle. Every Z and G he has worked on has had it. So it is normal and has been normal for the past 4-5 years with the Zs and Gs. Research 2 piece flywheels if you want to know more about the design.
You want it gone? Get a one piece flywheel next time you do a clutch job.
Old Jul 4, 2008 | 07:54 PM
  #40
GiGGaplease's Avatar
GiGGaplease
im the other way around
engage is when its pushed it. dont know if that is the right way of saying it.
the sound came after like 2-3k miles, so this is not normal. if it was normal, it will make that sound right after i turn on the car the first time at the dealership.
Old Jul 5, 2008 | 01:35 PM
  #41
sharif@forged's Avatar
sharif@forged
When the pedal is pressed "engaged" the clutch is released or "disengaged.
So you engage the pedal, do disengage the clutch. Confusing?
Old Jul 5, 2008 | 02:21 PM
  #42
GiGGaplease
it doesnt matter which is which.
stevo4756
Oct 9, 2015 01:54 AM
parkern
Oct 5, 2015 12:12 PM
G37sPhoton
Oct 4, 2015 11:08 PM
parkern
Oct 1, 2015 10:15 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
