any get a creaking/squeeking sound from the clutch?
Old Oct 22, 2007 | 12:51 AM
]\[ /-\ ]\/['s Avatar
any 6MT owners get a creaking/squeeking sound from the clutch?
i just started getting this loud creaking/squeeking sound when i slowly let off the clutch
anyone get this?
Old Oct 22, 2007 | 01:26 AM
DetroitG37Joe's Avatar
DetroitG37Joe
No but I am starting to get the faint chirp when going from R to 1 and 1 to 2 mentioned in the other thread here! I wonder if the axle lube theory is behind all this BS....Thinkin about takin the ride back to INF to repair it if I continue hearing it for 1-2 more weeks. I assume it's nothing too severe.
Old Oct 22, 2007 | 01:38 AM
yea i have that issue to...guess i'll give it another week then take it in see if they can fix both noises
Old Oct 22, 2007 | 01:29 PM
likwidfuzion's Avatar
likwidfuzion
I get the squeek on the clutch when I let it out on first gear/neutral. It happens in my old car as well so it doesn't bother me.
Old Oct 22, 2007 | 01:51 PM
ivory37's Avatar
ivory37
I never heard the clutch squeak. But I always hear the axle lube thing so I dont know.
Old Oct 22, 2007 | 03:36 PM
DetroitG37Joe
Yep axle lube things looks like the Japs (no WWII connotation intended whatsoever) had soem kind of specs off and it's happening on what seems to sound like 4 out of every 5 G's.....Interesting. I am making an appointment for it when my car is broken in at 1200 mi....I figure by then if it's an issue of needing to be broken in and it resolves then cool, but if not by then I will get it fixed. Im only at 450 mi now so if anything it ain't too severe and by the time im at 1200 I am assuming nearly every service dept will be aware of it and know EXACTLY what to do....
Old Oct 24, 2007 | 09:08 PM
dangphilzill's Avatar
dangphilzill
i definitely hear my clutch squeaking sometimes. do you hear a loud clunk sometimes wen your shifting from 1st to 2nd or when from 1,2 to neutral? i dont know if this is a serious problem or not..
Old Oct 24, 2007 | 09:48 PM
doesn't the manual say something about a clunking sound? but i think its just the way u drive...i get it too sometimes and i think its when i get off the clutch tooo fast
Old Oct 25, 2007 | 01:30 PM
dangphilzill
hmm i meant i get it when im in gear already, and i push down the clutch and there goes the clunk! before i even switch gears =T
well as long as it doesnt happen 24/7
Old Oct 25, 2007 | 01:51 PM
IP37's Avatar
IP37
if you're driving in a low gear, rpms up a little.. if you let off the gas, then just quickly hit the throttle then let go, is there a clunk?
just wondering.. my mustang was terrible about that...
Old Oct 26, 2007 | 08:01 PM
dangphilzill
mostly happens when... im in 1st gear accelerating and because of a short distance between stop signs.. rev 1st up to 25-3000 and clutch it into neutral. or even wen im switching to 2nd gear. clunk. dont know what it is... gear box problem?
Old Oct 26, 2007 | 09:36 PM
black fx-45's Avatar
black fx-45
I have the same problem also this is starting to remind me of my 2003 350z tranny problems.
Old Oct 27, 2007 | 02:06 PM
dangphilzill
so it is a tranny problem? is it a big issue? can it be fixed?? =T
Old Jan 30, 2008 | 06:02 AM
Kev G37S's Avatar
Kev G37S
I know it's an old thread but I've found out that I have the same problem as well. any solution now?!
Old Jan 30, 2008 | 12:53 PM
Kidcane's Avatar
Kidcane
Florida G Club
I just dropped my car off today and that was one of the things they are fixing. I dont think it is a tranny problem. They told me it was just a dry set of bushings making the sqeak.
