ECU Tuning / Dyno Data This subforum is specifically aimed at ECU Tuning reviews, questions, dyno charts, etc..
Should I turbocharge or supercharge my g37?
Old Nov 9, 2020 | 01:22 PM
munzer's Avatar
munzer
Hello guys,
so I want to add a supercharger/turbocharger for my g37 and I am confused on what should I add for the car. I mean, I will use the car as a daily and I definitly dont want it to explode. And can you add some recommended kits and to how many hp I can reach?
Thank youu
Popular Reply
Mar 31, 2021, 10:40 AM
jpowersjr2's Avatar
jpowersjr2
Originally Posted by Broken_2008_G37
Where are you getting 20-25k from. I'd like you to itemize how much each thing would be. So then when you're done we can all say you're full of s**t.
Here you go bud:
(Some prices have changed slightly over time and labor rates are estimated for shops. Hours were obtained from contacting various ones.)
Any more comments you'd like to add?
Old Nov 9, 2020 | 06:48 PM
dkmura's Avatar
dkmura
20 Year Member
I don't recommend a forced induction (FI) application for the VQ37VHR as a daily driver. It increases heat and stress on the drivetrain, and the drop in durability isn't worth it for a vehicle that you count on for getting to and from work. The G37 already has more than adequate performance, and there are other upgrades (fluids, brakes, suspension) to consider before FI.
Old Nov 10, 2020 | 01:22 AM
Birdie's Avatar
Birdie
How much power do you want is the main question? Then go from there
For a daily I would say supercharger. The car should make less torque but still have some good hp numbers. Less torque is better for the engine itself.
I would go with SOHO motorsports or topgunz air to air kits only
Old Nov 10, 2020 | 08:04 AM
RMB5190's Avatar
RMB5190
If you're confused on what you need to go down this road, then you haven't done near enough research...
Old Nov 10, 2020 | 01:16 PM
munzer's Avatar
munzer
what about the stillen supercharger kit?
Old Nov 10, 2020 | 06:44 PM
Birdie's Avatar
Birdie
The stillen supercharger kit in my opinion is trash.The couplings it comes with are not made well and collapse under boost. It well be difficult to hold consistent numbers and the air to water intercooler heat soaks fast.Do not buy the out of the box tune.
these other brands are basically the same setup except without the flaws plus much cheaper in price
Old Nov 10, 2020 | 07:02 PM
stealthee's Avatar
stealthee
Cheap
Fast
Reliable
You can only have two.
If you want cheap and fast, it won't be reliable.
If you want cheap and reliable, it won't be fast.
If you want fast and reliable, it won't be cheap.
As was previously stated modding a daily driver is not a good idea. Been there and done that. If you had another car to daily and this was just going to be a fun car then there isn't really an issue, however I have one word, and that is RESEARCH.
Old Nov 16, 2020 | 01:41 PM
jpowersjr2's Avatar
jpowersjr2
Whatever FI option you go with, expect to spend a minimum of $15k to do it right. A twin turbo setup will cost closer to $20-$25k.
Old Nov 16, 2020 | 10:26 PM
Epiphany's Avatar
Epiphany
Sell the G, take your budget+what you get for the G and buy something faster.
Old Mar 30, 2021 | 11:14 PM
Broken_2008_G37's Avatar
Broken_2008_G37
Old Mar 30, 2021 | 11:20 PM
Broken_2008_G37
Originally Posted by munzer
Hello guys,
Thank youu
Its a hard choice. I've been kicking the idea back and fourth myself... At first it was "strictly turbo" for me.. because of the hp numbers. Then I saw a lot of SOHO supercharged kits making 550+ w/stock bottom end. I'm also FBO so I wouldn't have to touch my headers or exhaust or anything... However this isnt my daily... Its my 3rd car. I have my jeep wrangler and my every day beater honda. I have a second motor im going to completely build so i'm more than likely going to go with their turbo application... but I've read a lot of good reviews on the soho supercharger kit as well. I should be posting my build here in the next couple weeks.
Old Mar 31, 2021 | 08:59 AM
RMB5190's Avatar
RMB5190
Agree with you @Broken_2008_G37 . SOHO or TopGunz kit are great set-ups. @jpowersjr2 isn't far off with the 15k figure. SC kit is anything from 7-8k, Clutch kit is another grand or two, fuel pump, injectors, tune, bigger wheels and tires, suspension; your costs will add up. 20-25k is in line with a built AT.
The kit themselves aren't as outrageous as they once were now that there's a few more options. Once you add in the cost of the supporting mods he's in the ball park.
Old Mar 31, 2021 | 10:40 AM
jpowersjr2's Avatar
jpowersjr2
Here you go bud:
Old Apr 1, 2021 | 10:49 AM
Atittle's Avatar
Atittle
A couple more things to consider before dropping a huge amount of money into a FI build.
- Do you have a open rear end? I have a vert with the TopGunz kit, I opted to have a Tomei 1.5 installed ( 950$ ish plus shipping including new seals and bearings, so about 1400$ all said and done )
- As much as we like to think it won't happen to us, be prepared and fully aware that even babied motors and hell built motors still go bang. So another spare motor to replace is around 1500$ - 2000$ ( I have a low milage complete motor for if or better yet when my goes ). This is assuming you can install it yourself if not need to factor labor
TLDR - fully research your options and what you are willing to spend then add a few thousand to that for issues
Good luck
Old Apr 1, 2021 | 11:07 AM
That was a mic-drop moment if ever there was.
