ECU Tuning / Dyno Data This subforum is specifically aimed at ECU Tuning reviews, questions, dyno charts, etc..
K&N Panel Filter Before/After Dyno Video
Old 11-14-2016, 09:47 PM
SonicVQ
SonicVQ's Avatar
Originally Posted by 4doorfury
I hate to say this but I call BS. I did the same testing and gained 2-3 peak whp and same wtq. This was 3 back to back with stock filters, 3 without filters, 3 with k and n. The biggest bump was with no filters where I got about 5 whp but same 2-3 wtq as k and n. Also, the filter he uses in the video is a fram and not genuine infiniti.
Interesting difference...
Could you post your dyno graph? I would like to compare shape of the HP & torque lines.
Is your G37 have RWD or AWD and auto or manual tranny?
Old 11-14-2016, 09:49 PM
4doorfury
4doorfury's Avatar
The original dyno of with and without air filters is in my build thread. With the filters in I don't have because the guys computer wasn't able to print that day and I also almost lost my car because a strap broke. Ghetto dyno ftl
Old 11-14-2016, 09:52 PM
SonicVQ
SonicVQ's Avatar
^^^ Wow, very fast reply
Glad your car didn't slide off the dyno...
I will have a look at your build thread.
Old 11-14-2016, 10:07 PM
4doorfury
4doorfury's Avatar
It did fall off thankfully it was an in ground dyno and the car just fell sideways on the rollers. Thought it was going to rip my tire apart but didn't.
Old 11-14-2016, 10:54 PM
SonicVQ
SonicVQ's Avatar
Just looked at your dyno and your dyno operator made a mistake.
Your correction factor is shown as "SAE 1.00", BUT it can't be if the temperature is 91.7, 30.18 pressure with a humidity of 38%. The SAE correction factor is 1.00 when temp is 77 degF, pressure is 29.234 inHg and humidity is 0%.
Your results are at least 2-3% higher than graphed. (Assuming the dyno operator didn't screw with anything else like over tightening a strap)
You might want to get your car dynoed again at a different shop. I suspect you will be happy with the result.
Old 11-14-2016, 10:57 PM
4doorfury
4doorfury's Avatar
Oh for certain. I won't be going back there ever again. Either way though, no changes were made except the removal of the filters and the gains were negligible. In fact, after back to back pulls, the numbers with filters and without started to be exactly the same. This dyno I also showed no gains at all with r2c intakes installed.
Old 11-15-2016, 09:25 AM
misc
misc's Avatar
By R2C you mean the short ram system, not the drop ins correct?
Old 11-15-2016, 09:28 AM
4doorfury
4doorfury's Avatar
Yes. The drop ins were k and n
Old 04-11-2024, 07:24 AM
camopaint0707
camopaint0707's Avatar
I came here from the dyno video, that's extremely surprising results, especially with 0 tuning
Old 04-11-2024, 04:02 PM
socketz67
socketz67's Avatar
Our cars respond well to K&N filters, Silicon Intakes and a resealing of the area where the intake meets the radiator support.
