Review Z1 Motorsports Transmission mount/bushing on '13 G37S 6spd.
I'll add my experience with the Z1 transmission mount here also. I'll add more as I drive the car.
At the moment, I have the car on jack stand still. I started the car up and at idle there's a subtle vibration. The vibration is more felt as I rev the engine. I thought my y-pipe was hitting the chassis or transmission cross member, but it was actually from the stiffness of the transmission mount. Hopefully, I'll have the car done this week to drive it to experience it with load and on the road.
Latez
Latez
Latez
I have a Topspeed exhaust. I'm sure the vibration will be different during a drive, under loaded conditions. I have a good tolerance for noise and vibration overall. I just forgot I had installed the tranny mount and thought my y-pipe was hitting again, since it happened before. I all for responsiveness and willing to sacrifice some comfort for it.But I can also understand this might be much for some.
Latez
Latez
I now have the car back on the road and was about to get a day's with of driving yesterday along with this morning's 60 miles commute.
As mentioned by 4DRZ and me, NVH increased. I'll try to rate it on a scale system;
0 = no vibration 5 = race car, solid everything, caged vibration
Cold start = 2 , due to the higher rpm, the vibrations is felt more but calms down to a 1 after the rpm settle
Idle = 1 , vibrations can be felt but not bad, very subtle to me
accelerating from idle up to 2500rpm = 2
2500-3000rpm (regular driving around parking lot and city streets)= 3
3000rpm-redline (hard acceleration) = 3.5 , at a certain point with all the noise from my exhaust, the road noise, and wind, you start to notice it
deceleration (in gear low speed) = 4 , certain rpms are worst than others, I think around 3000rpm and right at 2000rpm, shifter shakes and vibration felt through seat and up the steering wheel.
cruising (high speed 50-80 mph) = 1 , its actually fairly smooth driving on the hwy
I'll add more or revise as I drive more. I'm not sure I can feel a difference in terms of responsiveness in shifting, maybe because its been 5 weeks since I've last driven my car, or my oem transmission mount wasn't in that bad of a shape.
Latez
Latez
Latez
Latez
Where I noticed the most difference in shifting was either stepping on the gas or off of it and watching the shift ****. You could actually see it move forward or backward and that made it difficult to shift smoothly. The trans mount definitely helped this issue, but it was the motor mounts and rear differential brace that really tightened things up.
Panda- You do get a bit more vibration as our engines are not exactly "smooth" by today's standards, but I wish you would have shown a before and after of the shifter when you let off the gas and how much it moves stock compared to with the Z1 trans mount. Night and day difference to take out a lot of the slop in the shifter. With motor mounts, a shift kit, and a rear differential brace the shifting is super solid in my car.
I just had Z1 motor mounts installed yesterday. The diff brace is a more significant add, IMO, and at a fraction of the cost because installing the mounts is so labor intensive.
I was wondering what you would think of the motor mounts compared to the diff brace. I noticed pretty significant differences from both, but in a different way. I guess they both take out a lot of unwanted slop in the drivetrain so that means the diff brace is looking like the new champion of bang for the buck upgrades.
Solid trans mount on auto g37
Had the Gk Tech solid trans mount installed on my 2015 Q60. It’s an absolute beast and sounds like a Lamborghini but a little more “alien like”. yeah it vibrates like a ***** at 80 on the freeway, but I only use the freeway to get to the mountain I tear up so meh. Once on the mountain I don’t really notice it.
have the diff brace and thinking of doing motor mounts next. Might run both z1 poly or one side poly one side solid depending. Might focus on chassis welding or roll bar first.
any input on solid trans mount is welcome as I have read on many drag forums you shouldn’t run solid all the way around but not sure with our cars.
I don’t mind the noise. I’m only driving 60 miles a week up and down a canyon. Otherwise it’s the sweet sounds of my electric bicycle: “Neeeeeeeee”
I just don’t want anything breaking due to torque or vibrations.
#29
indeed they are not: Very Quick 3.7 Very High Revolution does not imply smoothness.
I think you might change your tune about a solid trans mount once you hear it. That 370Z mount I was telling you about was LOUD as in it sounded like there was no exhaust on the car at all and I could not hear my radio. Race car loud.
#30
There are plenty of smooth high rev motors out there.
