MotorSport Ranch Speedway (Cresson) Nov. 28th SIGN UP!!!
Old Nov 22, 2005 | 11:31 PM
  #76
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
Originally Posted by mr_ecktid
Oh man I was hoping I could get away with the oil change. I guess Friday I'll go get it changed and ask them to check all the fluids and stuff. I just got my tires installed yesterday, they look real beefy, my rims look tiny now. Hopefully I can get my brake kit installed tomorrow *Crosses fingers,* I really don't want to wait until Friday.....
-Mark
P.S. When I was calling shops around for estimates on installation of the kit (Don't feel like stressing out Moog with the install) the first shop I went to quoted me $550 for install!!! The second shop quoted me around $150-$200, so I was pretty content with that. But then I decided to call this one last shop (redline in arlington) and they quoted me $75 for EVERYTHING (Rotors/Pads/Brake Lines/Fluid)!!! Not just that but they said it would only take like an hour or two to finish, while all the other guys quoted me 4-5 hours. Does this sound too good to be true?
Just be sure to look over their shoulder when they're working...
Old Nov 25, 2005 | 09:03 PM
  #77
JD_AND_DA_G_RIDE's Avatar
JD_AND_DA_G_RIDE
Umm, tell me where they're located at. For some reason I wanna say to go with someone else.
Old Nov 26, 2005 | 02:41 PM
  #78
mr_ecktid
Guest
Posts: n/a
They're in Arlington, TX. But they're my last chance to get them installed, so I have to go with them :\ hopefully everything works out, if it doesn't and my brakes fail on the highway, at least I got to meet you guys
Old Nov 26, 2005 | 07:13 PM
  #79
ApexDriving's Avatar
ApexDriving
If you do not get it done I have a shop at the track and we could do it in the morn.
Just an offer.
Old Nov 26, 2005 | 07:45 PM
  #80
rwjcp721's Avatar
rwjcp721
Okay, for those of you that will be racing on Monday, here's a quick list to follow before track day...
3. Check your brake pads to make sure you have enough meat for the day.
How much pad would you say that we should have before the day starts?
Old Nov 27, 2005 | 01:26 AM
  #81
mr_ecktid
Guest
Posts: n/a
Okay guys, everything turned out fine. They took about two hours, and charged $67. The only negative to them was that I noticed my rear left tire was put on with some camber so it looks like this / instead of | . The camber isn't SUPER bad. I actually didn't notice it until the car pulled to the right slightly on the highway. I'm just going to jack it up tomorrow and fix it, should take 5 minutes.
Soooooooooooooo
Oil Change - CHECK
New Tires - CHECK
Brake kit - CHECK
YAY
Old Nov 27, 2005 | 10:14 AM
  #82
ApexDriving
It is very hard to say. You are the one the will be controlling the brakes. I would like to see around 50% for drivers that are new to the track. If you have pad bring them out and we can get them put on if you need them.
Old Nov 27, 2005 | 10:24 PM
  #83
mr_ecktid
Guest
Posts: n/a
Do I need to bring a sack lunch or something tomorrow?
Old Nov 28, 2005 | 09:53 PM
  #84
ApexDriving
Thanks for coming out guys! Hope you had a good time!
ajosowiecky
Sep 30, 2015 12:15 PM
