Installed paddles on G37x Coupe but won't upshift
Old May 30, 2021 | 07:04 PM
JakeC's Avatar
JakeC
Hello
I have a 2010 G37x coupe and I just had paddle shifters installed since the X doesn't come with paddles from factory. I purchased oem paddles and it will downshift but not upshift, everything was installed and wired correctly as far as I can tell. Does the car need to be programed or something?
Old May 30, 2021 | 07:37 PM
ILM-NC G37S's Avatar
ILM-NC G37S
No programming. Entirely plug-and-play provided the harness came preinstalled in your car.
Do you have a multimeter and do you know how to check continuity? If so, you can check the paddle shifter switch itself.
Old May 30, 2021 | 07:48 PM
JakeC's Avatar
JakeC
Thanks for the quick response!
I have a multimeter, how do I check continuity?
Old May 30, 2021 | 08:10 PM
ILM-NC G37S
Here's a quick tutorial on testing for continuity: Fluke Meters, just FYI.
Set the meter to read continuity and disconnect the wiring connector for the paddle shifter.
Place probes on switch terminals (pins) NOT the connector itself. It does not matter which probe to which pin. Your meter should read "OL" (open line/ loop).
Now, use a strong rubber band to pull and hold the paddle toward the steering wheel while you touch the probes to the pins. Your meter reading should change from "OL" to a numeric value and may even beep. This indicates the circuit path is closed meaning the paddle switch is good.
If the meter still reads "OL" when you pull on the paddle, then the switch is probably bad.
Old May 31, 2021 | 11:33 AM
JakeC's Avatar
JakeC
OK I'll give it a shot. Thanks for the detailed reply!
Old Jun 1, 2021 | 12:12 AM
iCrap's Avatar
iCrap
you can open up the paddle, and bend down the little metal piece which slides to make contact and repair the switch. I have done it before, not too hard.
Old Jun 1, 2021 | 03:36 PM
JakeC's Avatar
JakeC
Thanks for the info!
Old Aug 14, 2025 | 09:25 PM
King300's Avatar
King300
I was installing a new carbon fiber paddle shifter, and I messed that little copper piece up, so i purchased a new paddle shifter, and the same thing happened, it bent it, and I think it's getting no contact do you know how I can fix it?
How to i secure that copper piece back??
Old Aug 25, 2025 | 02:45 PM
King300's Avatar
King300
please I need some help I purchased new carbon paddle shifters and now my upshift won’t work i purchased 3 different oem ones and it keeps breaking the little metal contact inside I don’t know why but it’s very frustrating at this point
Carfanatic
16
May 21, 2026 06:42 PM
syrusdavirus
14
Jan 17, 2021 06:17 PM
Dan G37
Mar 9, 2018 01:37 PM
sheff
18
Apr 3, 2010 07:54 AM
Alex57r
Oct 8, 2009 09:24 AM
