K&N Panel Engine Air Filter
Old May 9, 2019 | 06:06 PM
kore.vq's Avatar
kore.vq
So I was changing out my engine air filters from cheap old disposable air filters for K&N filters but while i was trying to put the part back into the air box it was quite hard to push the metal connectors back on. I was wondering if anyone else had this same experience or if i should check something out. the regular old ones went back in fine but i dont really know why the new ones were harder to put in. maybe just cause im inexperienced
Old May 10, 2019 | 03:03 AM
Said Amir's Avatar
Said Amir
That is normal, same thing on my car. The rubber around it just a bit thicker so crap does not go around the edges, but more through the filter it self. Also make sure that when you oil them up do not use a lot of oil or it will leak out through the holes of the air filter housing from the bottom and get all over the inner fenders. Don't ask how i know lol.
Old May 10, 2019 | 10:24 AM
telcoman's Avatar
telcoman
Poor quality control on aftermarket parts most likely made in China?
I'm on my third Infiniti and never had that problem over the past fourteen years and over 300k miles. I change my air filters roughly every 10k miles
Then again I only use OEM air filters that I purchase at the dealer and get my 10% discount, sometimes more.
Telcoman
Old May 11, 2019 | 03:24 AM
usedG37's Avatar
usedG37
Telcoman
No, K&N is manufactured and designed in Riverside. has thicker rubber seal than OEM
ImportPartsPro
Brakes/Suspension
202
Sep 2, 2015 12:34 PM
tite_tite
Dec 26, 2014 05:24 PM
masterk1
Intake and Exhaust
May 20, 2013 04:55 PM
panomotion
Aug 19, 2011 12:29 PM
