DIY: Slip & “VDC OFF “ lights on after steering rack replacement
My steering rack was in terrible condition and I HAD to replace it , the install was straight forward and simple , didn’t run into any problems whatsoever , also replaced the PS high pressure line , car steering is excellent and smooth, however my “Slip” & “VDC OFF” lights are now on my dash , not too sure why , the replacement rack was plug and play , nothing left unplugged or hanging and prettt simple , not sure what’s up , any ideas ??
Welcome to the Forum Edwin. Check your brake fluid level. the slip and VDC lights go on together to indicate low brake fluid. some may have been removed/spilt while RRing the rack.
Good luck and please post up if this solved the problem or if you have further questions.
also PM sent.
also PM sent.
Marcasummers
12
07-23-2017 05:28 PM
