Motorvate's DIY: Use any ODP app/scanner to see how dirty your throttle body is
Old Aug 20, 2018 | 09:05 PM
MotorvateDIY's Avatar
MotorvateDIY
Use any OBD app and scanner to see how dirty your throttle body is without opening the hood or getting your hands dirty.
This episode is the result of almost 3 years of data collection using OBD Fusion's diagnostic report. This report allowed me to see the slow changes that occurred over years.
Old Aug 21, 2018 | 08:22 AM
NealP's Avatar
NealP
Another great video with lots of useful information, thanks!
Old Aug 21, 2018 | 01:50 PM
MotorvateDIY
Thank you NeilP!
Just to give you a behind the scenes view:
It took a total of 40 hours to produce that 7 minute video!
(organizing data, creating scripts, recording audio, creating graphics and animations)
I better get back to work on the next episode...
Old Aug 22, 2018 | 02:08 PM
JSolo's Avatar
JSolo
Just say no!!!!!
2012 G37S @ 35K miles . I'd say it's doing pretty good. It should be noted, about 2K miles ago (before last road trip) all 3 resets were done (no tb cleaning). Why? Why not. I would think if there is build up then even after resets, absolute values would still be higher because the tb valves can't fully close.
I also had some issues with the nissan ex addon working. It seems i've never actually used torque in any great capacity since getting this phone january of 2017. Back then I just restored torque and settings using titanium backup as the app itself doesn't have an import/export settings function. To get the nissan ex addon working again I had to uninstall it, delete NADV pids under settings/manage extra pids/clear list, reinstall the addon, then add predefined pids under settings/manage extra pids. That's why the pic below isn't showing vvt temp or engine rpm. It's working correctly now.
Motorvate's DIY: Use any ODP app/scanner to see how dirty your throttle body is-lvrpwvz.png
Old Aug 22, 2018 | 04:39 PM
Baadnewsburr's Avatar
Baadnewsburr
Originally Posted by MotorvateDIY
Thank you NeilP!
I don't doubt that it took so long given the high quality of the productions.
I'm not sure how you thought of the video ideas for this OBD 2 series b ut they are really good.
I thought I knew how to use my scanners and diagnose issues and didn't expect to learn so much from them but t they are so helpful especially how you break things down...thanks again for your hard work man
Old Aug 23, 2018 | 03:06 PM
qmantran's Avatar
qmantran
It would be much easier to just remove the throttle body and visually inspect lol. Loosen the intake clamps, remove 4 Allen key bolts. Done.
Old Aug 26, 2018 | 08:58 AM
MotorvateDIY
Thanks! The OBD scanner provide a lot of information, BUT they are not easy to understand what it means...
That's the problem I am going fix.
The InfinitiEX plugin can be tricky to get it to work, but it does provide a lot of nice information, like oil temp.
Old Aug 26, 2018 | 09:00 AM
MotorvateDIY
As with many things, there are different ways to do them, just pick the one you like best.
Old Dec 22, 2025 | 06:41 PM
thompsoncry's Avatar
thompsoncry
Thank you NeilP!
DIY posts like this are great because they show how small insights — like checking how dirty your throttle body is — can make a real difference in performance and enjoyment. It’s a reminder that thoughtful tools and habits matter more than hype or shortcuts. The same goes for personal routines: the ones that feel intuitive and supportive help you stick with progress over time. That’s why I think platforms like https://wellness‑app.com/ fasting tracker app are cool — they focus on practical, steady support that helps you stay consistent without overwhelming you.
thanks for the information!
Q8y_drifter
381
Mar 23, 2023 12:56 AM
Dannymuller7
Intake and Exhaust
Apr 26, 2019 12:17 PM
gchou626
Jun 20, 2013 03:14 PM
kdawg8526
Intake and Exhaust
Apr 15, 2013 04:21 PM
