Bought a G! what maintenace should I do first?
Old Mar 19, 2017 | 08:06 PM
dmill86's Avatar
dmill86
I just bought my first G and I would like to hear your opinions on what maintenance I should tackle first based on the mileage. The car was bought used and has had two previous owners. It has 108,000km (aprox. 68k miles) service records only really show multi point inspection and engine oil changes. if this was your car, what maintenance would you perform first? Differential oil change perhaps? Any advice is much appreciated. Thanks
Old Mar 19, 2017 | 08:58 PM
micafd3s's Avatar
micafd3s
id change all the fluids and filters...
Old Mar 19, 2017 | 10:04 PM
Also check your brake pad thickness.
Old Mar 19, 2017 | 10:37 PM
Bravo at's Avatar
Bravo at
Everything above plus spark plugs, drop the oil pan and clean it, clean the throttle bodies, clean the MAFs, swap the PCVs, and probably the serpentine belt for starters. Give the battery a good charge and reset the ECU. Then the just clean everything!
If you plan to mod then consider starting your build thread now. Welcome.
