Help with fog light replacement
Old Apr 19, 2015 | 01:04 AM
Gthirtysevenx's Avatar
Gthirtysevenx
I have been installing my new diode dynamic LED fog lights in my 2012 G37x and am stuck!
I managed to the pry back the plastic wheel well on the driver side and easily plugged in that bulb. On the passenger side, I am not sure how to work around the washer reservoir.
I may need to take it in to get help somewhere.
Old Apr 19, 2015 | 02:33 AM
wowwed's Avatar
wowwed
Easiest way might be jacking up the car and going from the bottom thru that plastic part. The splash guard or whatever it's called
Old Apr 19, 2015 | 01:04 PM
Gthirtysevenx
Great thank you.
Old Apr 20, 2015 | 11:27 AM
G37sPhoton's Avatar
G37sPhoton
hopefully you got it, but if not ^^^wowwed is the way i did mine too. took of the bolt- about 4-5 if i recall, bent the plastic back and reached in there. there is only the one top nut if you want to take the whole unit out- on this side with the reservoir, it takes a little bit of reaching(and tearing skin) but doable. once there, just twist and out etc.. good luck- are you upgrading bulb?
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
G37xhibeet
Sep 4, 2015 03:00 PM
bikerjosh
Aug 19, 2015 11:26 PM
