DIY: Poor mans "Hyper" LED DRL's Sport version v1
Old Mar 12, 2015 | 10:26 AM
djdiskino's Avatar
djdiskino
Lightbulb DIY: Poor mans "Hyper" LED DRL's Sport version v1
I was admiring the Hyper LED's that Infiniti sells for around $600 and decided that it was entirely too much money to spend on some simple LED's. So here is my first attempt at fabricating anything of my own out of metal. This project will be continually updated to completion but I figured I would post what I have so far.
Materials:
-I started with a 12x12" piece of Steel Sheet Metal (Found in Lowes or HD)
-Purchased some Aviation Snips from Harbor Freight. Link
-LED Eagle Eye lights from Amazon. I made sure the ones I got were 3watts each. These have a threaded extension on them and a nut to attach them easily to anything you want to mount them to. They are also waterproof!
Link Link
Tools Required:
-Dremel or Drill with sanding, metal cutting wheel, and a step drill bit.
-Something to cut the metal - like the aviation snips above.
-Hammer and rubber mallet - used to flatten out the metal.
I started off making a carboard mock-up of the shape of the Fog grill insert. I decided I wanted the plates aligned along the outside. Once I was happy with that I traced it on the metal with a Sharpie and after several careful cuts and pinched fingers I ended up with plates that sit just inside the grill inserts.
DIY: Poor mans "Hyper" LED DRL's Sport version v1-0y03ny0.jpg
After I was happy with the mockups I got to drilling (this was the hardest part) I used a step-bit I purchased from Harbor Freight. Link I used the smallest one and drilled all the way down to about the 3rd to the last step of the bit.
Caution: these bits and the metal get VERY hot and will burn your hands and other stuff around it. I actually drilled these on top of a stack of soft cardboard which almost caught fire.
Another note - you'll see the metal bends inwards from all the pressure and drilling just around the hole - you'll have to find a clean-hard-flat surface like concrete or a metal block to hammer the plate back into shape after all the drilling is done. I used normal hammer to flatten where the hole was made and then used a larger rubber mallet to flatten out the whole panel as a whole. Here is what they looked like after.
DIY: Poor mans "Hyper" LED DRL's Sport version v1-bbmg85r.jpg
See how the metal is black/brown around the edges of the holes? Yea.. it got that hot.
I also took the liberty of rubbing a dremel to clean up all the sharp edges around the outside of the panel and the inside of the holes.
Time to test fit LED's and make sure they all fit. Here is a test fit of one after drilling one of the holes. (notice the sharpie markings of where I planned to drill my holes)
DIY: Poor mans "Hyper" LED DRL's Sport version v1-gwdes90.jpg
Making sure my plates sit nice on the Fog Inserts with all their holes now done.
DIY: Poor mans "Hyper" LED DRL's Sport version v1-cunmjcj.jpg
The next step I placed the plate over the fog and used my dremel sanding tool to essentially burn/melt a hole in the fog insert exactly where the plate hole lines up. I held the plate in place where it's final position would be and just inserted the dremel through the hole into the grill insert - applied light pressure because I did not want to bend my fog insert tabs on the backside.
Once you are able to get all the hole done you should be able to push you wires through all 3 holes on each plate and the thread of the LED Eagle Eye should stick out the back of the fog insert. You can then use the nut to tighten them down and secure them.
DIY: Poor mans "Hyper" LED DRL's Sport version v1-wgvy7hm.jpg
Here is my set - somewhat complete. Still needs paint. I plan to paint them black first (for rust purposes) then I am doing to put a smooth coat of Plastidip over them to make them blend a bit better with the fog area as the plastic is not a deep black like the paint.
DIY: Poor mans "Hyper" LED DRL's Sport version v1-zpgeqi7.jpg
Testing 1...2...3... - Used a 9V battery to test here.
DIY: Poor mans "Hyper" LED DRL's Sport version v1-irsszeb.jpg
Finally painted them Black - then dipped them black because I felt the rubberized look of the dip meshes better with the grill color than a deep black. Final shots, I may make another pair and get a more exact template or I'll try a template that fits the full Mesh area to make it one solid plate so no mesh crosshatching is seen on the fog grill insert.
DIY: Poor mans "Hyper" LED DRL's Sport version v1-jcg55w0.jpg
DIY: Poor mans "Hyper" LED DRL's Sport version v1-dysa8aj.jpg
Here is a video. Tested with a 12V DC Source.
Old Mar 12, 2015 | 11:14 AM
pledes23's Avatar
pledes23
Very good write up!! I'm curious as to why you didn't want to use the template where you wanted to holes, drilled into the plastics and just mounted the LEDs directly onto the plastics without the metal piece?
Old Mar 12, 2015 | 11:16 AM
djdiskino's Avatar
djdiskino
@pledes23 good question. I initially thought of doing that but if you look close at the fog/grill insert it's got that cross print texture on it that is very uneven. I couldn't find a way to get a straight line that I liked that didn't look like I was just slapping some LED's randomly on the insert. This metal piece gives me a nice smooth surface to mount to and gives it a more finished look.
Old Mar 12, 2015 | 06:11 PM
pledes23's Avatar
pledes23
I agree with your point completely. I guess it's more me being **** because the entire fog housings texture will be mismatched. Overall you did a great job and I will probably consider doing something similar when summer approaches. Do you know if those LEDs you purchased are offered in 6000K?
Old Mar 12, 2015 | 06:53 PM
Yan141's Avatar
Yan141
Looks good........
Old Mar 12, 2015 | 07:13 PM
djdiskino's Avatar
djdiskino
No worries. I thought about it a lot on ways to blend it in with the texture even going as far as making my own rubber molds but this just seemed to work. I think once they are black and have that kind of rough plastidip texture they will look like they fit better. So hard to paint in the winter here.
6000k they definitely have eagle eye leds on eBay somewhere. I specifically wanted these in 4300k to match my custom headlights I'm working on which have 4300k led evil eyes
Old Mar 13, 2015 | 01:35 PM
pledes23's Avatar
pledes23
Oh ok great! I'm in for updated pictures when painted and also when installed!
Old Mar 13, 2015 | 03:37 PM
Flakman's Avatar
Flakman
Thanks for the idea. I just ordered a 10x set from ebay. When I get them I'm gonna take out the inserts and see what options I have fir the mounting. Since I have the '09, those panels have nothing in them, so I have lots of leeway to mount how I want.
Old Mar 13, 2015 | 05:02 PM
djdiskino's Avatar
djdiskino
@Flakman those '09 panels are much easier to work with and don't have all the corners and edges that these have. Your's should be an easy little project. The housings I believe are supposed to keep the LED's cool because at 3watts they will need a heatsink to draw the heat away or they will burn up.
Old Mar 23, 2015 | 12:55 PM
Flakman's Avatar
Flakman
Alas, the '09 panels are part of the bumper and don't come off. Time to figure out something else
Old Mar 23, 2015 | 12:59 PM
djdiskino's Avatar
djdiskino
Ahh - the panels attached to the bumper are possibly the worst idea - makes everything so much harder to work on. My solution will still work but you'd have to get some really good measurements and do a lot of test fitting. The DRL's will hold the panel in place like mine you'll just have to be very careful drilling through the bumper panel.
G37xhibeet
Nov 15, 2016 09:29 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
sydnrusty
Nov 21, 2015 10:42 PM
drewfinity
Sep 25, 2015 04:08 PM
