traction control
Old Jun 17, 2014 | 04:34 PM
oquainb's Avatar
oquainb
traction control
I have a 2010 g37 I know if you pull the stop llight fuse it cancels traction control and everything to be able to do a burnout. What I was wondering is there a way to put that fuse to a switch so I dont have to pull it everytime
Old Jun 19, 2014 | 11:38 AM
TeeItHi's Avatar
TeeItHi
Brake stand/burn out
here you go. i did this over the winter and had fun on winter tires. lol
hopefully my explanation will make sense or pics should explain itself.
- pic 5 & 7 - i broke the fuse and then solder wire in each end. you can see from the 2 pics that i had to remove some of the plastic in order to have room for soldering and that i can only solder on top of the leads and if i solder too close to the middle the fuse will not fit back in
- i use a inline fuse holder and attached it to the switch.
for now i just have the cable/switch by the left side of the seat. i will be switching switch to a flip cover style switch when i have time and put it next to vdc & trunk release.
Attached Thumbnails traction control-005.jpg   traction control-006.jpg   traction control-001.jpg   traction control-004.jpg
Old Jun 19, 2014 | 01:33 PM
Chris11LE's Avatar
Chris11LE
Any idea what happens if you do this on an AWD car?
Does the car then run SOLELY with AWD and no other nannies?
Ive always been curious how the car would act with only the AWD system to keep it in line.
Old Jun 19, 2014 | 02:08 PM
TeeItHi's Avatar
TeeItHi
just try it i guess
[QUOTE=Chris11LE;3792231]Any idea what happens if you do this on an AWD car?
Ive always been curious how the car would act with only the AWD system to keep it in line.[/QUOTE
you may have to brake harder if it works.
Old Nov 12, 2014 | 08:19 PM
ncg37's Avatar
ncg37
Thanks... Can't wait to try this...
Old Mar 6, 2016 | 07:48 AM
Mattlorentzoe's Avatar
Mattlorentzoe
I'm curious also! Did you try it?
vamarris
Dec 9, 2018 11:10 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Landshark
Sep 29, 2015 11:20 PM
m3clubracer
Sep 20, 2015 09:20 PM
