DIY: G37 Sedan Illuminated Door Sill Installation
Old Jan 4, 2019 | 08:46 AM
atreyu285's Avatar
atreyu285
So how would this work for a set that doesn't come with the t-harness? I have a 2010 g37xs
Old Jan 4, 2019 | 03:57 PM
jpowersjr2's Avatar
jpowersjr2
With the T-harness? Are you referring to where on side goes to the passenger side sill and the other splits off to be run from one side to the other for the driver sill? I bought a kit from iCrap so if you'll elaborate some more I can probably help.
Old Jan 4, 2019 | 06:54 PM
Str8Gtime's Avatar
Str8Gtime
No harness
Correct me if I’m wrong but I don’t believe it is a t harness- all 2nd gen g’s just had a harness for the illuminated kick plates. For those sold without them they are just a plug with nothing going into it?
If installing without a harness - just tap the two wires - if you need to know which wires then look up the diy section as it is explained with pictures
Old Jan 4, 2019 | 07:01 PM
jpowersjr2's Avatar
jpowersjr2
Yeah I think you're right Str8Gtime but I'm not sure if there's an extra plug or if it's just extra wires within the existing plug. If that makes sense.
But yeah tap the two wires mentioned in these threads and you'll be good.
FWIW I tried searching for the factory harness with no luck. You'd have to find a wrecked G with factory illuminated sills and pull the harness from it. Too much trouble and not needed.
Old Jan 4, 2019 | 11:08 PM
atreyu285's Avatar
atreyu285
Mine is straight aftermarket and looks like this
Old Jan 5, 2019 | 12:01 AM
Str8Gtime's Avatar
Str8Gtime
how did that turn out btw? got any after install pics?
Old Jan 5, 2019 | 12:18 AM
atreyu285's Avatar
atreyu285
I have yet to install. I am looking for answers on what I can tap into since I do not have the harness that is mentioned in the thread
Old Jan 5, 2019 | 12:21 AM
jpowersjr2's Avatar
jpowersjr2
Re-read the thread. Post #1 about halfway down. I don't have the harness either and this guide worked for me.
Old Jan 5, 2019 | 12:47 AM
Str8Gtime's Avatar
Str8Gtime
Establishing Connectivity
Remove the shielding on the harness to expose the wires
Switch to the illuminated sill harness - take a pair of wire cutters and remove the plug on the end of the harness. Ensure you are cutting the plug off IN FRONT of the inline fuse, and NOT either of the plugs that accept sills themselves.
Use a pair of t-tap wire connectors to connect the RED and WHITE wires from the sill harness to the BCM harness.
WHITE (SILL HARNESS) connects to > SKY BLUE (BCM HARNESS)
RED (SILL HARNESS) connects to > MINT GREEN (BCM HARNESS)
Looks like white wire from the kick plate goes to the plug pictured above and the sky blue wire
Red -> mint green from the same plug
I tapped this plug to install my footwell lighting. Pretty sure it is just the interior light / dome light circuit but if you are cautious like i was - maybe just buy an inline fuse just in case?
Old Jan 14, 2020 | 08:32 PM
KImChee's Avatar
KImChee
I installed these thanks to the instructions. Thank you!
Old May 5, 2020 | 05:28 PM
Rich11G37xS's Avatar
Rich11G37xS
what am I not seeing here, I happened to find the stock sills on a 2012G37x at a junk yard today , paid $5.....I took that connector off....so now Im just seeing a red and white wires....It looks like you have the red wire coming from the fuse? to the brownish connector and the white to the lt blue, I haven't used the T tap connectors...what am I missing here , is there another pic you can show ??
Old Aug 9, 2020 | 10:45 AM
Levi4689's Avatar
Levi4689
I already have illuminated kick plates but they need replacing. They don’t fully light up. Only the middle of the Infiniti lights up, not the full word. It looks really bad but since I already have the illuminated kick plates, if I could get some used ones that worked good, would it just be plug and play?
Old Aug 9, 2020 | 11:39 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by Levi4689
I already have illuminated kick plates but they need replacing. Since I already have the illuminated kick plates, if I could get some used ones that worked good, would it just be plug and play?
Yes, one connector for each sill. 15min. job at most.
Old Aug 9, 2020 | 11:41 AM
  #29
Levi4689's Avatar
Levi4689
Yo thanks for the response. That’s a bit of a relief. Good to hear it’s as easy as I thought.
Old May 25, 2023 | 03:34 PM
  #30
AMP_01's Avatar
AMP_01
Quick question:
What's stopping someone from tapping into the door lights that project towards the ground when you open it? Wouldn't that be much simpler?
