DIY: Steering Wheel Trim Removal/Replacement DIY
Old Feb 2, 2016 | 06:31 PM
  #91
VIVID's Avatar
VIVID
Pyroclastic Flow
Thanks OP and other contributors. Got mine CF'd and installed.
Sean
Old Feb 7, 2016 | 09:23 AM
  #92
jcote003's Avatar
jcote003
Awesome write up! Saving for later...
Old Mar 2, 2016 | 12:56 PM
  #93
m3clubracer's Avatar
m3clubracer
Originally Posted by mikaly
Example of what you can do with that old, scratched up trim:
(3M Di-Noc Black Carbon Fiber Wrap)
How was the 3M Di-Noc stuff to work with? It looks like the textured non-gloss. About to do this and all the DENTED and SCRATCHED aluminum in the car.
Old Mar 3, 2016 | 01:20 PM
  #94
Debonair's Avatar
Debonair
Sean
What did you use to remove the remaining rubber coating before applying the CF vinyl?
Old Mar 9, 2016 | 12:36 AM
  #95
Very helpful write up. Thanks alot OP will be doing mine this week hopefully.
Old May 29, 2016 | 01:54 PM
  #96
user84292004's Avatar
user84292004
Registered to say..
OP - Thank You for the detailed writeup on trim replacement and steering wheel removal!
Swapped my trim this morning, was fairly quick; without this info, would've definitely doubled or even quadruple the time it took.
Thank You!
/2008 G35S
Edit: anybody want my old trim for wrapping, let me know.
Old Dec 11, 2016 | 09:28 AM
  #97
turbohounds's Avatar
turbohounds
Thanks for the instructions; it was surprisingly easy to get everything apart to get to the trim.
Don't try this without a heat gun and loads of patience. I went with the 3M brushed aluminum to try to match the washi.
Old Dec 26, 2016 | 10:46 PM
  #98
folarin86's Avatar
folarin86
Im new here, the Fiber wrap looks so good . Dont know if their is anyone that can help .Is this just a 3m wrap or a new dash trim.
Old Dec 26, 2016 | 10:53 PM
  #99
folarin86's Avatar
folarin86
Please I need some help with the 3m wrap . It really looks great .
Old Feb 5, 2017 | 10:24 AM
  #100
maxtog's Avatar
maxtog
Thanks, OP, for this thread. Mine is out of warranty now and that damn plastic "soft coating" is sticky and scratching off. I can't tell you how much that trim piece annoys me. It isn't just that it is unattractive in a nearly perfect car, the rubbery stuff is "sticky", so it annoys me every time I place my fingers on it... which is most of the time I drive. Photo attached.
I can't believe a $1 piece of plastic that sold for $7 now has an MSRP of $144 and sells, discount, for over $100. Insane!!
I don't think I like the idea of trying to paint it or cover it. Haven't ordered the part yet, still thinking about what I am going to do....
Attached Thumbnails Steering Wheel Trim Removal/Replacement DIY-steeringplastic.jpg
Old Feb 19, 2017 | 03:33 PM
  #101
maxtog's Avatar
maxtog
Well, I bit the bullet and spent the $117.37 and bought it from orderinfinitiparts.com. Installed it today and it only took an hour, and that included time to clean the leather wheel really well! I wish to thank the forum members so much for the information and instructions.
I sold my old (rubbery coated) trim piece on Ebay. It went quickly!
Old Jun 5, 2017 | 10:24 PM
  #102
krava's Avatar
krava
Got mine wrapped in 3M 1080 Matte Black vinyl ($7.58/eBay) for OEM look
Old Jun 12, 2017 | 09:05 AM
  #103
mikaly's Avatar
mikaly
Black vinyl looks good!
Old Jul 23, 2017 | 11:29 PM
  #104
Moses Lim's Avatar
Moses Lim
In step 3, the 2 bolts that holds down the airbag tray. Is there a recommend torque? Not sure if there should be any play to let the tray spring in and out. Or do I tighten it until the tray is snugged with the other component. Thanks in advance.
Old Mar 26, 2018 | 10:34 PM
  #105
Sama786's Avatar
Sama786
Does anyone know where I can buy the steering bezel trim since everywhere online has it for $100+?
Also if anyone in the Houston area can do mine for me I can pay them a reasonable amount.
I know the part numbers are as shown below but the prices are crazy for a basic part.
48463-JK06A LIDSTEERING,RH - Black
48463-JK06B LIDSTEERING,RH - Beige
48463-JK07A LIDSTEERING,RH
48463-JK07B LIDSTEERING,RH
