Wheel torque spec?
But definitely worth it.
80-85 ft lb.
__________________
Harbor Freight has pretty good prices for torque wrenches if you are just looking for one to use on your wheels. I would not buy one there if I was planning on using it daily though. I bought one from them but can't remember the exact price, I believe it was on sale for under $50. They have a couple on sale right now for about $15
1/2" Torque Wrench
1/2" Torque Wrench
Air powered torque wrenches? They exist, but they're never right. Set it at 80, and you'll get somewhere near 80. Maybe 70, maybe 90, maybe 120 if you bump the regulator. Best thing, by far, is a good old fashioned manual torque wrench. Doing things too quickly can get you in trouble.
I have both the 3/8" and 1/2" torque wrenches from Harbor Freight and have been using them for years without any problems!
Just make sure to zero and lock it out once you're done using it. They are pretty cheap and are stated to be +/-4% which isn't bad. I torque to 85ft.lbs.
80 ft/lb for 2012 G37 per manual. And yes, I second the use of torque wrench. I bought it 7 years ago, and only use it when double checking after having new tires mounted, or installing secure lug nuts. Otherwise keep it safe in it's storage case. Still looks brand new, and it was not expensive for a precision tool.
