Request:Need help installing white leds for rear license plates lights
Old Nov 12, 2010 | 04:53 AM
tWistedMissiOn's Avatar
tWistedMissiOn
Hey i checked on the USDM, and yea, i just realized you guys don't have that side turn signal on your fenders... damn.. i'm alone on this then.. i wonder how i can open them.. Thanks for the help though.
Old Mar 1, 2011 | 05:13 PM
Steveo47's Avatar
Steveo47
if you take take the wash guard in the wheel well off you should be able to get a hold of it
Old Mar 2, 2011 | 03:07 PM
mitmot's Avatar
mitmot
Just wanted to thank you for the pictorial and instructions on replacing the bulbs. Took me about 20 minutes and it looks great!
Old Mar 2, 2011 | 03:51 PM
CDONNS's Avatar
CDONNS
No problem man, glad they helped
Old Aug 17, 2011 | 04:57 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
Originally Posted by CDONNS
Per your request, here's the dome and door light install. Just need a flat head screwdriver with some tape on the tip so that you don't scratch anything.
The dome light is a simple pop out, don't worry you won't break anything. It has four clips, two on each side....
The door lights are the same, pry it out. Then I would recommend disconnecting the wire harness, just push down the little clip and it'll come right off. Then, you'll want to pry off the clear plastic piece. Just pop one side off and you should be good to go. Once again, don't close everything up and put it back together until you verify you have them in correctly...
nice man, thanks for doing this
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
maybeg37
Sep 8, 2015 02:33 PM
