DIY: Changing G37 Fog Lights to 6K HID Xenon
Old Aug 2, 2015 | 05:29 PM
  #31
Epiphany's Avatar
Epiphany
Originally Posted by prichable
So I've already done the install but I'm having a hard time getting the right light to turn on. It's usually a hit or a miss to get both running at the same time and sometimes I have to switch the fogs on and off to try to get it on.
Switch the bulbs side to side and see if the issue stays on the right side or moves with the bulb. If the issue stays where it was it might be the ballast. Are you pulling power from the battery?
Old Aug 4, 2015 | 01:33 AM
  #32
prichable's Avatar
prichable
Okay I'll give that a try. No..I think? I have everything wired up to the existing cables that were for the fogs.
Old Aug 10, 2015 | 01:37 PM
  #33
prichable's Avatar
prichable
So I switched the bulbs, switched the ballast and even tried using the wiring harness to see if I can pull power from the battery with that and still nothing. I tried them all on the working side and the bulb and ballast are working fine. There has to be power running to the balast on the right because the ballast light is on.
Rayramg37
Nov 18, 2015 09:06 AM
Gefartenblatz
Nov 10, 2015 11:45 AM
pauliewalnutzz
Sep 8, 2015 11:41 AM
dlc1988
Sep 2, 2015 09:40 AM
