What size socket for cat bolts??
What size socket is needed for cat removal? Going to be doing mine sometime this week and want to make sure i have the correct size.
I think the 14mm works but a 9/16 does fit also, I had to use the 9/16 and an Impact gun with 1/2" drive, 32" extension to break the top bolt free this is the bolt that you have to get from the top which is right behind the intakes. When I used the 14mm on this bolt it seemed to be spinning a little bit, the 9/16 fit a little snugger on the bolt and actually worked. (future reference for anyone)
well yeah and if you bought new cats or tp chances are they supply them, it might be a good idea to go to a local store and pick up the same size stainless steel bolts though to help prevent rusting, but yeah I think I really got lucky without having to cut any of the stock bolts, I would suggest using an anti-seize lube on any nuts going further
ZSpeedPerformance
Supporting Vendors
Sep 4, 2015 11:09 AM
KZK
Canada
Sep 2, 2015 05:30 AM
