DIY: Sub and Amp Install DIY
Old Mar 27, 2009 | 12:32 PM
]\[ /-\ ]\/['s Avatar
yea that helped.... do you have any pics of you single rca soldered?
nah...i dont
i didn't solder either...just used quick connects
once you cut one end of the single RCA you'll c the 2 wires (+,-) i'm talking bout and have a better understanding
Old Mar 27, 2009 | 12:38 PM
Originally Posted by Age
Nice post man.. but what are all the cables I need to buy, I found these 2-channel audio interconnect cable but I don't know if I need that. Also a couple people told me that walmart has kits with everything uou need, I guess ill need to check that out
http://cgi.ebay.com/NEW-LEGACY-1600W...3%3A1|294%3A50
went with something like that...has all the wires you'll need and i wanted 4ga and 20ft long power cable...i think 18ft will be a lil too short
Old Mar 27, 2009 | 12:47 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Originally Posted by ]\[ /-\ ]\/[
nah...i dont
Thanks man...
I wonder if it matters if the RCAs are cheapos or expensive.... I want a good signal but damn, cuttin up nice RCA cables will be FTL.
Old Mar 27, 2009 | 12:53 PM
finagle69's Avatar
finagle69
Thanks man...
I soldered mine, but I didn't even use an RCA cable.
I bought a pack of (2) solderable (is that a word??) RCA connectors from effing RadioShack. You do not need to spend bank on Monster Cable crap.
Old Mar 27, 2009 | 01:11 PM
MaxToTheG37
never heard of those... what they look like/
Old Mar 27, 2009 | 01:16 PM
finagle69's Avatar
finagle69
it's just the end of an RCA cable. This is what i bought. http://www.radioshack.com/product/in...ductId=2102841
Old Mar 27, 2009 | 01:24 PM
MaxToTheG37
so you ran speaker wire with these connectors? did it not have to be shielded or anything?
Old Mar 27, 2009 | 01:31 PM
finagle69's Avatar
finagle69
Yeah, I tapped into the same wires mentioned in the DIY with solder onto speaker cable. then soldered this RCA connector onto the other end of the speaker cable. then connected the RCA Y-splitter and into the back of the amp.
The 16 guage speaker cable soldered to a quasi-gold plated RCA connector has better conductivity than anything coming from Monster Cable or anyone else, lol. you just have to take your time so that the leads don't touch each other. It's not too difficult.
EDIT: about shielding: as long as you aren't running the length of cable parallel to a power conductor, you are fine without shielding. Since this tapped cable comes from the oposite side of the car (left where the bose amp is) than where my power wire was run (along the right side of the car from battery), they never get close enough to each other to cause any problems.
Old Mar 27, 2009 | 01:44 PM
MaxToTheG37
thanks bro.... all this good info will help me big time tomorrow!!
Old Mar 27, 2009 | 01:54 PM
finagle69's Avatar
finagle69
np, Ben. if you need some help while installing, just shoot me a PM
Old Mar 27, 2009 | 08:07 PM
Finagle's the man!
thanks again for the help when i did mine's
Old Mar 27, 2009 | 09:22 PM
finagle69's Avatar
finagle69
Finagle's the man!
no problem bro. does it sound nice?
Old Mar 27, 2009 | 11:06 PM
ProstylezG37's Avatar
ProstylezG37
man...gonna have to holla at one of ya soon..got all these audio goodies but havent had time to install....
Old May 10, 2009 | 06:39 PM
  #29
linet90's Avatar
linet90
I'm a little confused with your install, you tapped wire to the speaker leads coming from the factory amp to a RCA jack then plugged it into the amp???
and if you did why? and why not use a line converter?
Old May 11, 2009 | 12:37 PM
  #30
finagle69's Avatar
finagle69
the JL amp has a line converter built in... why spend more money?
