DIY: SPC A-arm Installation (Front Camber Adjust)
Old Dec 18, 2010 | 09:47 PM
  #31
1cleanG's Avatar
1cleanG
NextLevel Performance
amazing writeup....just used this thread to install my front SPC kit. DEF made it a no brainer. ANYONE can do this w/ this thread!!!
Old Dec 23, 2010 | 01:24 PM
  #32
Steveo47's Avatar
Steveo47
So i did this last night WITHOUT touching the strut.
1) Jack up car (always use a stand)
2) Remove wheel
3)Now, i removed the camber arm from the wheel hub, which allowed me to wiggle the stock arm around. This is the part which lets you NOT remove the strut. Looks at where the arms connect, and see if the bolt can come out without touching the spring, if so your good to go, just undo the bolt and push it out.
If it does touch the spring and you cant remove it, place a jack behind the rotor on the arm which connects to the car and slowly jack it up, this will compress the spring and consequently move if out of the way, once its out of the wat remove the bolts and continue with the DIY!
CAUTION: when lowering the jack used to jack up the wheel hub, SLOWLY, VERY SLOWLY, low the jack, i made the mistake of turning it to quick and it slammed my car onto the jack stand.
Old Aug 21, 2011 | 01:28 AM
  #33
huwee06's Avatar
huwee06
so who all left their caster at 0 degree? Will it be off from the oem? Or should I go with -.5 lol very new to this camber stuff.
Currently dropped on stechs and go moar low next week on coilovers.
Old Sep 29, 2011 | 07:15 PM
  #34
D_Rek's Avatar
D_Rek
I did mine and this help me.
Old Oct 4, 2011 | 08:28 PM
  #35
A_Palaroan's Avatar
A_Palaroan
hey guys im about to do this and was wondering approximately how long the DIY takes. I know its will take everyone a different time but what is the average? thanks
Old Nov 9, 2011 | 12:57 AM
  #36
frty9rsfn's Avatar
frty9rsfn
hey guys, i did the install and the front arm is hitting the fender underwall... is this normal?? i got the revised spc fronts but it is hitting when going over a big bump... this isntall is on a 08 coupe... please help!!
Old Aug 21, 2012 | 06:10 AM
  #37
jon23's Avatar
jon23
Wow, I just found this thread. What a great write up! I'll use it for sure when I get my front control arms, which should be soon. Thanks OP!
Old Jan 18, 2013 | 06:06 AM
  #38
SgtGoldy's Avatar
SgtGoldy
Thanks for this
Old May 12, 2013 | 01:14 AM
  #39
washduce's Avatar
washduce
Thanks for the thread...changed my front control arms today and it worked great.
Old Sep 21, 2013 | 05:53 PM
  #40
mindonmatter's Avatar
mindonmatter
A big thank you to finagle69. This was a piece of cake thanks to your write up.
A question for anyone who's installed the SPC kit. Did you leave it a 0 degrees caster?
Old Mar 24, 2014 | 10:47 AM
  #41
robertg37's Avatar
robertg37
SPC A-Arm install and steering rack problem
I used this DIY and the next day I was turning the wheels to back out of a parking spot. The right side of the steering rack rod that turns the tire broke in half. I am sending it to my mechanic to see what happened but does anyone have any ideas?
Old Aug 12, 2014 | 10:36 AM
  #42
Jack10525's Avatar
Jack10525
For those that have changed out the A-arms what springs do you have? Do eibach springs require this on front and back?
Old Aug 14, 2014 | 09:58 PM
  #43
mr_nlu's Avatar
mr_nlu
THANKS SO MUCH! i will be needing this in a couple of days. only part I'm iffy about is step 4 with the end link. Anyone have tips/pointers for this part?
Old Mar 25, 2015 | 01:57 PM
  #44
Sunny G's Avatar
Sunny G
Guys I need some help. I am experiencing a bottoming out effect with this kit. I was told to use the bump gaurds and put them on the strut. My question is where do I put them on the strut? I am going MAD over this
Old Oct 2, 2016 | 06:32 PM
  #45
007pipeline's Avatar
007pipeline
thanks... this helped me a lot this weekend
