DIY: G37 all headlight bulb replacement
Old Jan 19, 2014 | 09:35 AM
  #211
TONY37X's Avatar
TONY37X
Originally Posted by HeHateMe
The orig post should be edited. For a 2009 g37 sedan the fogs are 9006, NOT H1! After taking it all apart and pulling out the bulb I now have to order the correct set and wait another week.
The OP was for a coupe which takes an H1 bulb, but you are correct the sedan takes 9006. Page 4 Post #95 of this thread points that out. You should always double check lighting type through Lamp Replacement Guide Home
Old Jan 20, 2014 | 08:15 AM
  #212
HeHateMe's Avatar
HeHateMe
Agreed. But nowhere in the orig post does it say that it's only for a coupe. Most people aren't going to read every page of the thread. It's a great write up, but I think that additional sedan info in the very first post would be beneficial to a lot of people.
Old Jan 23, 2014 | 09:09 AM
  #213
MistaYoung's Avatar
MistaYoung
Great Write-up!
Old Apr 1, 2014 | 02:32 PM
  #214
Mr Infinit's Avatar
Mr Infinit
If I were you I would give this 35w kit from DDM Tuning a try:
DDM Tuning 35W and 55W HID Kits
I've had one of their 35w H8 6000k kits in my Fog lights on my 2010 G37x and now transferred it to my 2013 G37x, going on 4-years with no problems, and at this price of $30 you can't go wrong! Matches my 6000k HID headlamps near perfectly. (See my profile pix)
Did the H1 HID foglight bulb fit inside the housing perfectly??
Instructions on the site say you may have to dremel the housing to make it bigger for the H1 HID bulb to fit..
Old Apr 1, 2014 | 02:44 PM
  #215
TONY37X's Avatar
TONY37X
I don't know about H1, as stated above "coupe which takes an H1 bulb, but you are correct the sedan takes 9006. Page 4 Post #95 of this thread points that out."
On the sedan however the 9006 bulbs are 100% plug-n-play, no Mod. needed.
Old Apr 1, 2014 | 03:20 PM
  #216
Mr Infinit's Avatar
Mr Infinit
My bad I thought you were referring to H1 HID bulbs from DDM tuning..
as I have a coupe and contemplating getting the H1 HID foglight kit from DDM tuning..
Old Aug 9, 2014 | 11:12 AM
  #217
JT2014's Avatar
JT2014
I went from the top to only replace the fogs... What a PITA!!!!!
Contortionist to get in there with a flashlight & see, tore up my fingers feeling for the clip, 20 minutes to get the clips hooked back, & on the passenger side remove the clip holding the washer neck to get some more room.
Old Oct 18, 2014 | 04:29 PM
  #218
tite_tite's Avatar
tite_tite
* So just got done with the 2010 G37x SEDAN INSTALL, went through the fender by turning the wheels in one side at a time and pulling back the shielding. This access worked well for the HID headlamp swap.
Also NOTE: When you insert the HID bulb or H8 into the fog light housing, look at it from the front as you apply forward pressure and turn the bulb to lock it in place, Making sure that all three prongs are above the mounting tabs or the bulb will not seat properly. I also took the extra time to find a spot to zip-tie the ballasts so that they would not be loose and sliding around. This is easier to do on the driver side because of the better visibility and availability of random holes to use as anchors.
* And as always, Be sure to test each lamp before closing up the fender and under engine shielding. Total install time was about 1.5 hours including testing, mounting and figuring the first side out
Hi,
I was able to change the driver side but the passenger was different. Can you advise on how to change the passenger side?
Thanks.
Old Oct 18, 2014 | 04:31 PM
  #219
tite_tite's Avatar
tite_tite
Unless you have a 2010 sedan, then the fogs are obviously in the lower bumper
Gunna try and change mine now to my new PIAA H8 Xtreme White Bulbs
Hi,
Thanks.
Old Oct 21, 2014 | 12:20 AM
  #220
stevo4756's Avatar
stevo4756
Has anyone tried anything like this in the integrated fogs on sport coupe (2008)?
http://www.ebay.com/itm/2014-Newest-40W-4800LM-Set-White-Cree-LED-Headlight-Lamp-Kit-20W-Bulbs-H1-H3-H7-/281430381224?pt=Motors_Car_Truck_Parts_Accessories&hash=item41868ed2a8&vxp=mtr
This thing looks hefty , but my only issue is the heat sink might stick out too far to put the fog cap on?
any ideas? Suggestions?
Old Dec 4, 2014 | 09:06 AM
  #221
TONY37X's Avatar
TONY37X
Originally Posted by tite_tite
Hi,
Thanks.
Repost from page 7 of this thread: NOTE: Passenger Side fog light on the G37x sedan can NOT be accessed through fender because of windshield fluid tank in the way, so you have to remove 3 bolts from under the front bumper on that side, pull back the shielding and create a gap to get at through there. Just reminded of that when I returned my lamps to stock for the return.
Old Dec 8, 2014 | 08:04 AM
  #222
genesisJDM370gt's Avatar
genesisJDM370gt
so helpful thanks
Old Feb 28, 2015 | 03:59 PM
  #223
Sway_NV's Avatar
Sway_NV
I'm too young to die!
Changing the fog lights on this car are unnecessarily annoying to replace lol
Old Mar 26, 2015 | 10:48 PM
  #224
niclacoste's Avatar
niclacoste
Thumbs up DIY: How to Install D2S HID Bulbs | Infiniti G35 G37 Sedan or Coupe 2007-2014
Hey guys I made an installation video, I hope this helps.
Model: Morimoto XB35
Color: 6000K
Type: D2S
Old Mar 27, 2015 | 08:45 AM
  #225
TONY37X's Avatar
TONY37X
Thumbs up
Color: 6000K
Type: D2S
Nice job with the video! And your right, the bulb clips are the trickiest part of the install, done it a few times on my 2010 and now 2013 G37x Sedan and always seems to **** me off haha
