Black our Grill DIY Guide
Old Aug 11, 2008 | 06:39 AM
  #46
prutkows's Avatar
prutkows
Originally Posted by toastmaster
CtK,
I finally finished painting my grill matte black, against a black obsidian car. I only got a few pics up at http://rogertan.smugmug.com/gallery/...0_XTiVX#P-2-15.
After a number of attempts at this thing, I should share out some tips and lessons I picked up along the way. Keep in mind that I had very little painting experience prior to this, so this may only apply to the n00bs like me:
1. Don't use a low grit sandpaper like 100. The point isn't to strip off the chrome covering down to the plastic, but rather, provide a porous-enough surface for the primer to bond to. Use something like 320, or a scrubbing pad.
2. If you do take off too much, fill up holes/scratches/whatever with Bondo. Even if it looks somewhat okay with primer, the defects become magnified once the paint goes on. It's better to err on applying too much bondo (fumes aside) and sanding it down, than applying too little.
3. It pays to wait between coats. Some paint can instructions say something that all coats must go on within one hour, leading one to rush the job. I don't know if that's 100% necessary, but I found that if I was more patient between coats (a few hours at least), I was much less likely to get runs or uneven applications.
4. Try to hold the can upright and prop up the grill while painting. I wrote on this thread earlier about the random splotches I got. I'm convinced a few of the times this occurred was because the spray paint can was shooting out propellant, instead of paint, thereby affecting following applications done soon thereafter. This was probably due to holding the can at an odd angle.
5. For matte, don't bother wetsanding or using rubbing compound before clearcoat. Once you wetsand, you'll introduce some areas that aren't blended in perfectly, forcing you to use rubbing compound to smooth it out. Well, that basically means you polish the paint, thereby negating the beautiful matte effect.
6. For matte, get a matte clearcoat. Krylon makes one called Crystal Clear Acrylic or something, and it comes in Glossy, Satin, and Matte. I used matte, and it looks perfect for my purposes. I read in various places online that you can wetsand a glossy clearcoat to get a matte one, but I didn't feel it was worth the extra effort and potential risk, hence, the Krylon. It goes on a little thicker than the duplicolors, but hopefully after applying the primer and basecoats, you'll be experienced enough to avoid runs in the clear coat.
Hope this helps everyone interested in doing this.
Good luck,
Roger
looks good.
Old Aug 11, 2008 | 07:14 AM
  #47
CtK's Avatar
CtK
CtK,
Good luck,
Roger
wow that came out really well!!
Do you have a pic from a little farther away to show what the whole front end looks like??
I wonder how that would look on a Blue Slate G37??
thanks!!
Old Aug 11, 2008 | 09:28 PM
  #48
toastmaster's Avatar
toastmaster
Thanks!
Unfortunately, I don't have any pics from afar that would show the whole front end. I might be able to take some later in the week, but no guarantees.
Old Aug 11, 2008 | 11:55 PM
  #49
VIP G's Avatar
VIP G
Don't think it will look good on BS
Old Aug 20, 2008 | 11:40 PM
  #50
SirFer's Avatar
SirFer
My G is black, so is there any chance of me getting the grill to match my paint myself, or should I just have it professionally done? I like that matte black with the chrome strips and Fuji though...
Old Nov 6, 2008 | 09:43 AM
  #51
DdotRoq's Avatar
DdotRoq
Any noobs have done this and noticed paint in good condition (ie. no rock chips, etc.)?
Old Nov 6, 2008 | 10:03 PM
  #52
G2Envy's Avatar
G2Envy
OMG this radiator cover was a biznatch to remove!! I ended up cracking the cover where the middle prongs are near the coolant reservoir. On top of that I dropped a bolt into the abyss and had to remove the intakes before squeezing my arms way down there to get it back. Try doing this in the dark with all those clips being harder than a mother to take out.
I wasn't expecting a 2.5 hour job just to remove the grill so it got dark on me quick! Add to that my flashlight losing battery power and you've got yourself a cursing factory. My neighbors must think I'm crazy for dropping all those "F" bombs and "S" bombs.
Tomorrow begins the sanding and painting and I plan on taking the whole day to paint. Don't wanna rush this part of it.
Old Nov 6, 2008 | 10:23 PM
  #53
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
LoL, I timed myself... I took off the grille in 2 minutes and 21 seconds.
Old Nov 7, 2008 | 12:08 AM
  #54
G2Envy's Avatar
G2Envy
Thanks for rubbing it in. Did this include removing the radiator cover? Cause without that in the way it's not difficult to remove the grill at all.
Old Nov 7, 2008 | 12:13 AM
  #55
sTiLLBaLLiN37
Yeah, the radiator is included in that 2 minutes and 21 seconds LOL.. I've literally done 40-50 grilles thus far. However, I must admit, the first time, was a biatch!
Old Nov 7, 2008 | 12:21 AM
  #56
DetroitG37Joe's Avatar
DetroitG37Joe
Poor OP, such a good thread and hes banned lol
Old Nov 7, 2008 | 01:49 AM
  #57
VIP G's Avatar
VIP G
^^ why? its my DIY that he stole...
Old Nov 7, 2008 | 10:49 AM
  #58
DdotRoq's Avatar
DdotRoq
I think he would not be banned if he had ATLEAST given credit.
Old Dec 6, 2008 | 12:56 AM
  #59
Taka37's Avatar
Taka37
CtK,
Good luck,
Roger
This should be THE 6 commandments of painting your grill.
I just got done painting my grill matte black and can't say how much this helped.
except i rushed it a bit....
" the defects become magnified once the paint goes on." is so true...
I'll redo mine in couple of weeks with better paint and not rushing thru.
in the meanwhile, I'll post up some pictures.
taking out the grill wasn't so bad. or maybe the horror stories got me ready for it. The worst part was removing the large black cover, the one where all the screws screw onto.
Old Dec 7, 2008 | 02:04 PM
  #60
toastmaster
Cool--glad to have helped man!
