Black our Grill DIY Guide
Old Mar 27, 2008 | 01:50 AM
$teveNG37's Avatar
$teveNG37
( lol subject is supposed to be Black out Grill DIY Guide but now i cant fix it =/ ) you only need 1 can of paint
1. First remove the grill from the car (thats a pain in the a$$)
Sand the grill down with 100 grit sandpaper, here it is fully sanded
2. Apply the first coat of primer, I used Dupli-Color filler primer then a 2nd coat.
3. three out of three coats of ( Dupli-Color high temp Gloss Black):
4. three out of three coats of clear-coat is dry:
5. finished product back on car
Attached Thumbnails Black our Grill DIY Guide-100-grit-complete-sand.jpg   Black our Grill DIY Guide-2nd-coat-of-primer.jpg   Black our Grill DIY Guide-3rd-coat-of-black.jpg   Black our Grill DIY Guide-3rd-coat-of-clearcoat.jpg   Black our Grill DIY Guide-finished-product-back-on-car.jpg
Old Mar 27, 2008 | 02:21 AM
cvt's Avatar
cvt
wow...not bad for a do it yourself...can you take some closer shots to get closer looks at the finish?
Old Mar 27, 2008 | 03:09 AM
mahont's Avatar
mahont
pics from further away would be nice
solopresident's Avatar
solopresident
how do u rermove grill?
Old Mar 27, 2008 | 09:15 AM
Kidcane's Avatar
Kidcane
Florida G Club
1. Fully open hood assembly.
2. Remove reservoir tank. Refer to CO-15, "Removal and Installation".
3. Remove radiator core support ornament. Refer to DLK-214, "Removal and Installation".
4. Remove front grille mounting nuts (A).
5. Disengage pawls (A) of fixing front grille.
6. Pull front grille out toward vehicle front.
7. Remove the following parts after removing front grille.
Old Mar 27, 2008 | 09:17 AM
DiamondGCoupe's Avatar
DiamondGCoupe
Not bad your car actually looke like Blue Slate with the grill black!
Old Mar 27, 2008 | 09:50 AM
GiGGaplease's Avatar
GiGGaplease
pictures on how to remove it would have been good. turn out good, i will try this.
Old Mar 27, 2008 | 01:56 PM
$teveNG37's Avatar
$teveNG37
basic idea is take the black cover off in front of engine bay area. (about 10 bolts 10mm size and 6 plastic clips, with a screwdriver. Remove the 2 bolts that hold the radiator catch tank and slide it back, then push it back towards rear of car and slide it over to ***** that stick out near radiator catch tank. Then undo the 7 pinch-push clips and 2 pull clips from the inside and black cover will come off. Lastly remove the 5 screws on the inside of the grill and then pinch and push the 4 clips holding the grill in. Mt. Fuji symbol removes easily.
Old Mar 28, 2008 | 04:25 AM
Jkg37's Avatar
Jkg37
how hard was it to sand?
Old Mar 28, 2008 | 11:00 AM
nestle_!9's Avatar
nestle_!9
good job man ,,, i like it
Old Mar 28, 2008 | 11:14 AM
gan78mao's Avatar
gan78mao
i got to the point where i removed all the bolts but the cover does not shift tat much to slide over the *****. and where are the 7 pnch push clips?
Old Mar 28, 2008 | 01:53 PM
vinnys coupe's Avatar
vinnys coupe
looks good steve more shots ftw..
i think ima go over the emblem when i do it.
Old Mar 28, 2008 | 04:00 PM
G-WIZ KID's Avatar
G-WIZ KID
What about rock chips. It's gonna look horrible in a couple of weeks.
Old Mar 28, 2008 | 04:01 PM
Jkg37's Avatar
Jkg37
i wouldn't use dupli color spray can... it is not strong enough.. i would go buy airbrush and professional automotive paint.
Old Mar 28, 2008 | 08:35 PM
vinnys coupe
wha can u do to get around chips, bc im painting mine as well.. but getting it done..should i recommend anything
