Swirls on car window?
I know there are glass polishes out there but i was wondering if anybody has had any experience with using them? if you did could you explain what steps i should follow?
Once the glass surface has been washed and cleaned (detailers clay) any minor imperfections can be removed with an abrasive glass polish (Autoglym Car Class Polish or Zaino Z-12 Clear-View Glass Polish) Removes "light" scratches, acid water spots, bird and bug stains, including alkaline mineral deposits, and then smooths out etched glass
If you can catch your fingernail in the scratch 0.4 Mil (10µ) deep, you should consult a professional glass repair / replacement company.
Methodology
• Clean glass to remove dirt, dust or road grime from surfaces
• Use masking tape to protect windscreen rubber sealing
• Apply clay (Magic Clay®) and lubricant solution (Woolite™ / Water 5:1) onto the glass surface (Do not apply to plastic as dulling may occur.)
• Apply a quarter (coin) size amounts of CarPro CeriGlass and an LC Glass polishing pad, is made of dense polyurethane foam with very small cells. The pad’s density enables it to keep the glass polish on the surface, rather than soaking into the foam. You’ll use less polish to get the job done, despite its density; the pad still has plenty of flexibility to conform to the curvature of the glass, speed #4 on a PC random orbital polisher
• Heat caused by abrasive polishing can soften and damage glass; foam pad and product used must minimize heat build-up. Since glass is a poor heat conductor any friction heat built up from polishing must be kept to a minimum by using sufficient product and regular misting of both the polishing pad and glass surface with water.
• Apply to half of the windshield, polishing first in an up and down motion then in a left-to-right motion and then repeat on the other side, proceed to other glass surfaces.
• Go over the glass several times in each direction, glass will polish virtually residue free.
• Wipe off any residue, and polish with a clean dry 100% cotton Micro fibre cloth.
• Inspect glass for clarity and smoothness. Repeat if necessary.
Alternative products / methods:
a) Apply Zaino Z-12 with a damp cotton cloth to cool glass, apply to small sections at a time and allow to completely dry, buffing with a clean dry cotton towel. If there is any smearing or residue left just use Stoner’s Invisible Glass or any good quality glass cleaner to remove excess residue.
b) Glass Technology Inc - Glass Scratch Removal & Glass Scratch Repair | Glass Technology, Inc.
Alternative pads- these 4-inch ‘Metal Polishing Pads’ are made from 600 grit nylon (Scotchbrite®) and are designed for hard / rough surfaces like aluminium diamond plate, pitted aluminium, chrome, and glass. TOL
Methodology
superjoey
31
Mar 22, 2023 11:56 PM
