Weird paint issue
Old Aug 17, 2013 | 02:39 PM
inspector94's Avatar
inspector94
Weird paint issue
So i removed my grille to paint and i wrapped the front area with a garbage bag for a few days and the next day it rained so when i went to remove it the day after there is like some dull spots over the side and edges. The car is brand new so i know it wasn't there before it, looks like sticker residue but its not. I would take a picture but its not visible in it. Some other note is that its not visible when wet or when no sun is shinning on it. Any clue what it is? The clear coat?(don't see how that can happen) The bag melted on it?
Old Aug 18, 2013 | 05:52 AM
TOGWT's Avatar
TOGWT
Haze or Moisture Entrapment
Paint will sometimes show ‘hazing” after removing a car cover or plastic covering that has not allowed transpiration. The temporary hazing, which can appear as a slight dull discoloration, stain, or raised surface in the paint is caused by the paint finish absorbing moisture
Correction- In most cases, by applying Isopropyl alcohol (IPA) and exposure to heat (sunlight, heatgun or haidryer) which allows the moisture to evaporate within a few hours. For colder climates, moisture evaporation recovery can be accelerated by placing the vehicle indoors and using a portable infrared heat lamp (or professional-type heat gun). Allow the affected area to outgas by not using a wax or sealer on the affected are for a few days
Old Aug 18, 2013 | 07:17 AM
1G372nv's Avatar
1G372nv
You need to clean car dry area very well and buff or wax. This could be moisture entrapment or just the wax being removed showing a hazing look. GL
Old Aug 19, 2013 | 12:44 AM
inspector94
Thank you to both, i will give this a try and hopefully it works!
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
cconklin2
Jan 9, 2016 07:21 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
cvg37s
Sep 12, 2015 07:17 PM
