porter cable 7424XP
I'll definitely buy it from DI if I can't find it locally. I was just hoping to get it two hours ago vs 3-5 days... I'll stop by homedepot on my way home to see what they carry. Calling any store for stock check in Fresno sucks ball$ because everyone hires their own instead of hiring qualified candidates or anyone who cares about customer service. Sorry, went off topic there... I'll keep y'all posted!
This is exactly the type of grunt work I leave to the Infiniti Personal Assistant
. If you bought the car new, I'd recommend you do the same.
Yes it will. There are better products available than the 7424, but it's simple to use, cheap, and gets the job done. Other products have a little bit more of a learning curve IMO (not much) and are a lot more expensive. I am loving my Rupes Bigfoot in the little time I've used it. I hope to be able to do a full detail with it soon.
I think everyone should own a 7424xp before moving up. Even after I picked up and learned how to control my flex 3401 I still go back to my pc from time to time. Certain areas it just works better.
Make sure you put a black sharpie line on the backing plate of the PC. If it stops spinning, you aren't doing any work. Either you are pushing to hard or you don't have the pad flat.
OBG37
Aug 27, 2015 03:56 PM
