swirls after details
i just got a detail like 4 or 5 days ago... from bird**** on my car i wiped the whole car with a microfiber 2 or 3 timess since then and my whole car is filled with swirls again i dont know if i got a ****ty detail or its the microfiber towel i used so what i wana know is
1. how long till u see swirls on your car
2.how do you keep up the no swirl look
3. will compound remove light or medium swirls by hand
2. By polishing them out then washing and drying your car properly every time
3. Not very well at all by hand.
I would not suggest a rotary for someone who has never polished a car via machine before, a PC will help.
What is your location? Maybe I can help you find a quality detailer.
You can easily remove swirls with the right polish. I use Zaino's PC swirl remover and it does the job great by hand. It takes me much longer than someone who uses a PC but I only have to do it every couple months.
Are you washing your car, than wiping it dry with a microfiber or are you just wiping the dirt off dry. You should never wipe your car dry since it only causes swirls and rubs in the dirt.
The swirls may not be visible even when shining lights on the paint. Wipe the paint down with alcohol, then look at the paint under the lights.
