Polished my BO for the 1st time!!!
Old Jan 20, 2009 | 11:00 AM
Gamedog's Avatar
Gamedog
Sam Rothstein
^ Great tips right there... I know they weren't directed towards me, but that is all useful info for me since I just picked up a Cyclo and will be anewb at the whole detailing process... Thanks!
Old Jan 20, 2009 | 11:13 AM
Looks great. You're doing your part to keep BO the King of all colors. post your pics in the B4 N after section too.
Old Jan 20, 2009 | 12:24 PM
elite's Avatar
elite
Looks great! I need to get to it.
Old Jan 20, 2009 | 12:57 PM
aliiin's Avatar
aliiin
BMW Defector
looks good!
Old Jan 20, 2009 | 01:05 PM
XtatiC's Avatar
XtatiC
Originally Posted by Detailed Image
Excellent transformation XtatiC, especially for your first time using your buffer. You'll only get better every time you use the polisher and become more familiar with the polishes.
Regarding your polishing speeds, I typically will spread the product at a low speed (~3 on the dial) to outline my working area (usually 18" x 18" or smaller). Then once I'm ready to polish, kick it up full go to 5 or 6. The only time I don't run the buffer at full speed is if it's bothering / numbing my hands. There's usually a noticeable increase in vibration going from speed 5 to 6, but those are the speeds you want to use when breaking the polish down.
Regarding the dusting, my guess is you either used too much polish, or you weren't cleaning out / swapping out your pads and the product was building up and spitting out of the pad. I typically will use 3 pea sized drops per 18" x 18" working area, no more than that. Using too much polish will also diminish your results as you won't be able to completely break down the abrasives as effectively since the polish will dry up before it completely breaks down.
I typically use between 4 - 6 pads per coat of polish. After every 2 or 3 panels, I'll take the pad off (looks like polka dots all over) and swap it out for a fresh one. If you don't have multiple pads to use, then you want to make a conscious effort to clean out the pad after every panel. To do this, simply take a toothbrush and run the buffer at a low - medium speed and gently glide the brush over the foam pad. Do this away from the car as it will typically kick up a lot of product.
The combination of using the right amount of product and fresh pads typically yields little to no dusting for me, but it takes a lot of time and experience to master. Just keep those things in the back of your mind for your next polishing job and see if it's any better. On a car the size of the G, I'd estimate using 1.5 ounces of polish per coat or less to give you an idea.
Also, not sure how fast you moved the buffer, but you want to try to move the PC at a rate of 1" per second, which is SLOW. You want to be applying between 15 ~ 20 lbs of force on the head of the buffer as well when working the polish into the paint.
Back to the results, killer job again on your car, especially since it was your first time. Your results will only improve the more you get to practice with the buffer and polishes. Keep up the great work and keep us posted if anything I mentioned helps next time around.
Thanks for sharing and thanks for the kind words. Now enjoy your new finish, it's certainly night and day!
George
Thanks a lot George, after reading your post I see what I need to do different. I used way too much polish and only used 2 pads per coat.
One more question.. after polishing I put the pads in a bucket with water and a packet of the detergent that was sent with my kit. when I'm ready to use the pads again, what do I need to do with the pads to get them ready to go again?
Old Mar 10, 2009 | 12:57 PM
chasemyaccord's Avatar
chasemyaccord
Subscribed.
Old Mar 10, 2009 | 01:06 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
I've never used the little packet stuff, I just use a small drop of laundry detergent in the middle of the pad and work it with my thumb from the center of the pad to the edges, while rotating the pad with my other fingers. Then rinse them off doing the same thing. It takes about 3-5 minutes each pad but it gets the job done believe it or not. Then I put them all back on my Cyclo and spin the water out of them for a few seconds. Then just leave them in the garage face down on a MF towel to fully dry for a day or so. Should be good to go. My prior detailer told me about this cleaning method BTW.
Old Mar 10, 2009 | 01:37 PM
I actually use the pad cleaning powder and like it quite well. I put about a half a packet in 2 gallons of hot water and soak all my used pads in it usually overnight. It does a great job of breaking down the product where it comes right out of the pad and it doesn't have any soap residue like laundry or dish detergent might. The next day I can just rinse and wring them out with my hands and all the product comes right out. Then in the washing machine with some CG MF detergent along with my used towels. Works well for me.
Old Mar 10, 2009 | 02:43 PM
KnoxvilleG37's Avatar
KnoxvilleG37
BUMP to George @ DI for being one of the most helpful vendors on our site!!!
j50ny
Jul 21, 2017 10:46 AM
charneco
Feb 21, 2016 11:11 PM
inspector94
Sep 8, 2015 12:57 PM
