Polisher Question
Old Oct 7, 2008 | 06:17 PM
Foresite's Avatar
Foresite
Polisher Question
Whenever I polish the GEE using my Porter Cable polisher, it ends up with white power in everything, all the cracks in the windshield etc. The GEE is OB so it really shows up. How do you avoid that or get rid of it? Am I supposed to wash it again immediately after polishing before I wax?
Old Oct 7, 2008 | 06:24 PM
Blackjack's Avatar
Blackjack
Well, it's not the G nor the PC that's causing the dusting. It's likely the product you are using. Some dust more than others.
What products are you using? We can likely recommend some that dust less.
Old Oct 7, 2008 | 06:25 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
^ Exactly what I was gonna say...
Old Oct 7, 2008 | 06:34 PM
RedG37SNC's Avatar
RedG37SNC
Leaf blower is your friend
Old Oct 7, 2008 | 06:37 PM
Blackjack's Avatar
Blackjack
Originally Posted by RedG37SNC
Leave blower is your friend
Don't give away the tricks man. Lol, jk.
Old Oct 7, 2008 | 07:59 PM
finagle69's Avatar
finagle69
aside from some products dusting very readily, most products start to dust up when the product has been fully broken down.
maybe try working the product in a little less or applying a bit less pressure?
Old Oct 8, 2008 | 08:47 AM
Foresite's Avatar
Foresite
I was using Pinnacle Swirl Remover.
Old Oct 8, 2008 | 09:20 AM
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
+1
Another common reason why people see excessive dusting is that they overuse a pad for polishing. I personally swap out for a new pad roughly 4 times per coat. I hardly ever see any dusting and by switching pads that frequently it ensures you are getting the maximum cut and best possible finish. It also is easier to clean the pads when you are done.
You also could be using too much product as well.
George
Old Oct 8, 2008 | 09:16 PM
Seer's Avatar
Seer
You should invest in a last touch/final inspection spray. It's a little bit different than a detail spray, what they do is remove polishing oils, dust etc, so you can see the final surface after correction.
Menzerna and Meguiars both make a spray like this
Old Oct 9, 2008 | 09:44 AM
jay.diem's Avatar
jay.diem
^^ 50/50 water alchohol mix does the trick as well
Old Oct 9, 2008 | 10:18 AM
Seer's Avatar
Seer
yep it does.
Old Oct 9, 2008 | 12:14 PM
shumby's Avatar
shumby
Drink it right?
Old Oct 9, 2008 | 12:15 PM
Seer's Avatar
Seer
Originally Posted by shumby
Drink it right?
whiskey tastes better than isopropyl
Old Oct 10, 2008 | 08:59 AM
Foresite's Avatar
Foresite
Cleaning Pads
Originally Posted by Detailed Image
+1
George
Thanks for your help.
What is the best way to clean the pads?
Old Oct 10, 2008 | 09:04 AM
Don@Migliore's Avatar
Don@Migliore
I would purchase a pad cleaner from George at DI.
