Polisher Question
Old Oct 10, 2008 | 09:05 AM
Seer's Avatar
Seer
Originally Posted by Foresite
Thanks for your help.
What is the best way to clean the pads?
Get a dedicated foam pad cleaner, spray the pad, let it sit, agitate it under warm water (buy a pad agitator brush). Then spin dry on the highest setting on your buffer.
Alternatively, you can use an APC, like Meguiars APC+ cut 10:1 as your cleaning spray. Although some sprays come in a two pack, that also includes a conditioner/pad primer, but that also can be swapped out by just using a quick mist of detail spray or water.
Old Oct 10, 2008 | 09:06 AM
Blackjack's Avatar
Blackjack
Originally Posted by Don@Migliore
I would purchase a pad cleaner from George at DI.
+1 to pad cleaners. I've used the Pinnacle XMT Pad Cleaner as well and it works great. Need to try the Snappy Pad Cleaner from George!
Old Oct 10, 2008 | 09:07 AM
Seer's Avatar
Seer
i've used pinnacle xmt cleaner too, it works quite well, so does using an apc, but to be honest, I have yet to use a pad cleaner that did not work well. Seems like there are just a lot of good products on the market.
Old Oct 10, 2008 | 11:02 AM
I've used them. They work fantastic. I use about a half of one of those packs dissolved into a 2 gallon bucket full of hot water. I've put as many as 4 or 5 pads and several applicators in there to soak overnight, or at least a few hours. Then next day I wring them out and all the product comes out really easily. I usually machine wash them afterward and air dry them.
charneco
Feb 21, 2016 11:11 PM
TheIvoryG
Sep 23, 2015 02:06 AM
pauliewalnutzz
Sep 8, 2015 11:41 AM
