What is the best cleaner for Clear Bra?
Sure. No worries. Some polishes, compounds, and swirl removers contain micro-abrasives that dull the sharp edges of scratches and swirls so they do not catch light. Part of the detailing process as it will smooth imperfections in the clear coat. If you feel these polishes with abrasives, they almost feel "gritty". While they work magic on a paint's clearcoat they do not do so well on a flexible film. They have the tendency to dull them over time.
Does that help?
Some examples of polishes with abrasives are:
1) Poorboys SSR Line
2) Menzerna PO106FF
3) 3M Perfect-It
4) There are many others... If they claim to remove swirls, it likely has an abrasive.
Does that help?
2) Menzerna PO106FF
3) 3M Perfect-It
I tape off the edges of the Clear Bra before doing any polishing or waxing... If you don't normally a Quick Detailer will do it. If that doesn't cut it, use a 50/50 Isopropyl alcohol and water mix on the edge ONLY!
Mattimus
Oct 4, 2015 01:33 PM
